Tue, Jan 14, 5:54 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 14 4:58 am)
Subject: Problem selecting multiple parts for a magnet to affect...Paging Dr. Geep!..
Gareee ( ) posted Thu, 11 December 2003 at 9:17 PM · edited Tue, 03 September 2024 at 6:58 AM
PhilC recommended I use magnets to create some morphs for my tink dress... I am learning them quickly, but can't seem to figure out how to actuall affect more then one area at a time. I need to affect both the hip and left thigh parts of the dress at the same time..wasn't there a Dr. Geep tutorial about something like this?
EdW ( ) posted Thu, 11 December 2003 at 9:41 PM
You need to create your magnet for the hip and then select the magnet and go to properties. Once there you will see a drop down box. Click on it and select the body part, in this case the left thigh and then ok. If you check the parameters for the left thigh you will see that the magnet is now displayed as a parameter. From here all you need to do is adjust the mag zone and move the magnet to create the deformation. You need to spawn the morph for both the hip and the left thigh to save it for both body parts. Hope this helps some Ed
Cascade ( ) posted Thu, 11 December 2003 at 9:43 PM
The quick answer is to look at the properties of the Magnet (not the base or zone) the button is labelled
"Add element to deform".
Here are some links to Geep's tutorials on magnets
http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=895452
http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=1470482
These three also use magnets
http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=1492165
http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=1525097
http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=1530557
There are probably others as well, Dr. Geep likes his magnets. :)
geep ( ) posted Thu, 11 December 2003 at 11:24 PM
"Add element to deform". <---(for the "Mag" prop) Yup, Cascade has it ! That's what you need to do to affect both the Hip and Thigh at the same time with a single magnet. I don't like magnets ... I LUV magnets!!! ;=] cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
Gareee ( ) posted Fri, 12 December 2003 at 7:26 AM
I tried that, but couldn't seem to add the selected part. when you select the part, do you select the "-" sign, or do you select the part name itself?
Gareee ( ) posted Fri, 12 December 2003 at 7:29 AM
BTW Funny.. I searched for geep magnet and tutorial, and the search engine found nothing!
geep ( ) posted Fri, 12 December 2003 at 9:18 AM
TRY THIS ONE. cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Fri, 12 December 2003 at 9:20 AM
NaySayGuy must have done the "tune-up" on that engine. ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
Gareee ( ) posted Fri, 12 December 2003 at 9:26 AM
Yep... that's the one I remember! Thanks!
Gareee ( ) posted Fri, 12 December 2003 at 9:29 AM
Course I JUST remembered that I email the entire page to myself.. LOL!
Gareee ( ) posted Fri, 12 December 2003 at 9:29 PM
Well, Geep, I throw in the poser towel on magnets.. after 3 hours of wrangling, I couldn't achieve even one morph for one leg of tink's dress. I had your magnet tutorial open the entire time, but just cannot get the magnets to move what *I* want to move. How Capeses did the puppet morph set wwith those is beyond me. That said, once I load morph targets into the dress, is there a way to combine the morph targets of two peices (left thing and hip) of the dress, so the body part of the dress can pull of the morphs for both sections at once with one dial? Seems that if you can do it with multiple magnets, that you should be able to do it with two loaded morphs... I don't want to release this without skirt morphs.. there's nothing I hate worse then having to mess around with something new, and find out that it requires lots of work just to get things right. I did take a break from it for a while, and did tink's wand, smartpropped, and even added a 1 poly glow effect.. here's the current wip...so at least today wasn't a total loss...
Gareee ( ) posted Fri, 12 December 2003 at 9:30 PM
Oh, forgot.. that's with no post at all...and her wand "star" is actually a full 3d star on her wand...
geep ( ) posted Fri, 12 December 2003 at 10:05 PM
Hi Gareee, I'm sorry that you are unable to get the mags to do what you want. They are quite tricky and difficult to use for what you are trying to do ... but not impossible. Perhaps, a couple of tips ... Locate the Base inside of the area you are trying to "pull." Rotate the Base so that it is perpendicular to the area you want to move. Adjust the Zone (scale x,y,and z -and= location x, y, and zTran) so that it covers the area (i.e., polygons) that you want to affect. Change the Zone to Wireframe display mode if necessary to see what area will be affected. You may, also, need to adjust the Zone's "falloff" (i.e., graph) so that the "pull" is distributed inside the Zone properly. Now, use the Mag's yTran to "pull" the affected area into the desired location ... (Gosh, this is difficult when you have to use words instead of pics - but without the model in front of me on my screen, I can only surmise what you have.) Remember that you can "twist" the area, also, by using x, y, and zRotate of the Magnet. Sometimes, a little goes a long way so make changes slowly and carefully and one at a time. If a change goes in the wrong direction, use the "Undo" to go back to the previous condition. I hope this will help you. I can understand your frustration ... Dr Geep has "been there-done that" many, many times. cheers, (?) dr geep ;=] BTW - That 3D "star" is very impressive and your pic is excellent! BTW#2 - re: " ... I did take a break from it for a while, ... " This is not easy to do when things are not going the way you want ... "If I can just try ONE MORE THING ... " But, very often, walking away for a while gives you a fresh perspective when you return and ... sometimes, the solution drops right into place after a break. Just a thought ... ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
Gareee ( ) posted Fri, 12 December 2003 at 11:25 PM
Yep.. took a break, and am back at it yet again.. I wanted the props to remain in the character folder, and was following a lead someone else gave me... I lost both props in poser, and had to reload them both, re texture them in the material room, and am trying to make them the way I want... I want the wand, in the character's folder, smartpropped to the right hand, and I want the glow to be smart propped to the hand. Poser, OTOH, does not seem to agree... I might revisit the mags again, but I think I recreated them about 8 times, re positioned them, and screwed up again and again. I did NOT however try to have the base perpendicular, so might give it a shot or two more... It actually seems easier to make the morphs in lightwave, and import them one by one. If you can save the dress with the multiple magnet morphs, spanning different body parts of the dress, can you do the same with multiple clothes morphs loaded as well?
geep ( ) posted Fri, 12 December 2003 at 11:51 PM
Hi Gareee, Sure, why not. I think I would do it this way ... 1. Use Magnet(s) to make Morph(s) 2. Spawn Morph Target(s) 3. Delete the Magnet(s) 4. Set the Morph(s) to 1.000 5. Create a Full Body Morph cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Fri, 12 December 2003 at 11:56 PM
An after thought ... Have you checked the JPs of the dress to see if they are in the same location(s) as the Figure's? ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
Gareee ( ) posted Sat, 13 December 2003 at 12:07 AM
yeah.. the morphs I want to make are for extreme limb bends, like a front leg rotated 90 degrees forward. I get tear through then... I've got a set of morphs already made in lightwave, but heard the magnets were pretty easy, and the way to go.. maybe if you don't have lightwave.. LOL!
geep ( ) posted Sat, 13 December 2003 at 12:56 AM
Try adjusting the Joint Parameters for the dress, ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
Gareee ( ) posted Sat, 13 December 2003 at 8:05 AM
might try that as well.. can't hurt...
