Sat, Dec 28, 3:19 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 28 2:24 pm)
Subject: Wierd animation problem
Deep-Trances ( ) posted Thu, 11 December 2003 at 7:10 PM ยท edited Sat, 28 December 2024 at 2:55 PM
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=556366&Start=1&Artist=Deep%2DTrances&ByArtist=Yes
Hi everyone. I run Windows XP, and have Poser 4. I have a weird problem getting animation creation problem. I set the picture in the link as the first keyframe. When I move the scrubber, or when I change the frame number to another, the metal chair moves forward and melts into the female figure. Why is this happening?
jerr3d ( ) posted Thu, 11 December 2003 at 8:42 PM
That does sound weird. I would guess that either you are not using the main camera. Or you have more than one key frame for the chair.
xantor ( ) posted Thu, 11 December 2003 at 11:31 PM
You are best to position the chair on frame 1 of your animation before you do anything else because the keyframing in poser is a bit crap.
FanDancer ( ) posted Fri, 12 December 2003 at 7:43 AM
Deep trances.. when you set up your animation, make sure to check these things before going beyond frame 1. If you want your figure to move, but not the chair.. make sure that in frame 1.. you only have the figures body selected or body part selected that you intend to have moving. You shouldnt at this point have anything else selected. I.E. camera, chair..etc. Add your frames, and on the last frame of the sequence move ( the part of the character you want moving ) select the body part.. Move it to the postion you want it to be in at the end of that particular sequence.. then select the camera ( if you intend for it to move ) and do the same. You'll continue in this manner until everything you want moving is moving. And the chair will stay where you placed it in frame 1. I hope I didn't confuse you with this.. Good luck on your animation.
FanDancer ( ) posted Fri, 12 December 2003 at 7:45 AM
Oops I forgot to say taht you need to place your chair in the positon you want it to be in.. in frame 1.. then do nothign else with it once you have it in position.
Deep-Trances ( ) posted Fri, 12 December 2003 at 8:56 AM
Thanks everyone. I'll give this a try tonight and let you know if it works.
