Fri, Feb 7, 7:59 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 07 7:37 am)
Subject: DDRAM PC 400 or RDRAM
jibrielson ( ) posted Sat, 13 December 2003 at 3:48 AM ยท edited Fri, 07 February 2025 at 7:57 PM
ive two Pcs , P4 2 ghz ,Intel 850MV ,512mb Rdram , HD 10 + 40Gb and the new ones P4 ,2,6 ghz ,Asus P4 PE-x series , 512Ddram PC333, HD 30 + 40gb when i render poser figure with dynamic cloth or hair , both computer give me very slow response , and i think i should upgrade memory to 1Gb , My question is , in my county and town 1 GB DDRam Pc 400 cost like 1 GB Rdram PC800 , which one i should buy , because i think Rdram more powerfull ( ive trying in several job for video and render) , but its lack in next support , and i`ve never trying the DDram PC 400 thanks for help jibriel
stewer ( ) posted Sat, 13 December 2003 at 5:27 AM
I can't give you a definitive answer on the DDR vs RD question, but if you should notice a lot of hard disc activity during rendering, lowering the bucket size in the render settings can speed up things.
jibrielson ( ) posted Sat, 13 December 2003 at 2:15 PM
thanks stewer its works
stewer ( ) posted Sat, 13 December 2003 at 3:18 PM
For the RAM question, you might want to ask the Hardware/Technical forum for help.
whoopdat ( ) posted Sat, 13 December 2003 at 3:44 PM
If your system uses DDR333, getting DDR400 won't do any good, UNLESS you get RAM that can handle low latencies. And then you'll be playing with a lot of settings in bios to try and customize everything to get every ounce of power you can out of it. That's stuff that's normally reserved for the overclockers/enthusiasts. It can get ugly since there's so many brands and they all perform differently. DDR vs RDRAM is a no-contest. RDRAM has almost zero support (in the mainstream) since Intel changed everything to DDR. I'd rather get a new motherboard, cpu, and ram than buy more RDRAM. The 800 mhz fsb P4s are nice, very nice. This coming from an Athlon owner.
layingback ( ) posted Mon, 15 December 2003 at 10:23 AM
Agree with everything whoopdat wrote - even including the being an Athlon owner bit. A 2.6 P4 might be pushing it, depends on the age of the chip (newer prodcution run the better), but a 2.4 800 fsb can sometimes be overclocked to a 1G fsb and an effective 3.0 CPU if you're lucky - and the DDR400 is really good. If you can push a 2.6 to 1G fsb that would be 3.25 and an amazingly fast system as the faster fsb speeds up just about the whole system. Of course you'd have to replace/upgrade all the memory, and read up on overclocking (www.tomshardware.com, www.hardocp.com, www.overclockers.com). And be lucky ;-)
