Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 18 8:37 pm)
Please don't be offended if I'm saying what you already know and is blatantly obvious here. But just in case any newbies to Poser are unfamiliar... at the most basic level, if you Pose your figure in frame 1, and then go to (say) frame 30 and effect a different pose, you'll have created a smooth animation transition between the two poses. That simple!
One other thing is the interpolation you are using. Poser default to spline interpolation which means everything moves in an arc. Most of the time you will need to created intermediate keyframes to control the motion of certain body parts so they don't fly way out of control. If you open the graph editor you can easily see any movements that are way out of whack. Simply create a keyframe and move it back into line. When you are first learning it's easier to change the interpolation to linear. You can always go back and change areas to spline. I never animate at 30fps. Most of what I do is made for web delivery so I tend to animate at 12 or 15 fps. Ed
Okay this is my question, I have gotten to the point where I know how to go and make an animation within poser 5. But what if I want to make one frame by frame? Say from one pose to another etc? Someone please help! thanks-_Essie
