Tue, Nov 19, 8:38 AM CST
Subject: Making figures
xantor ( ) posted Sun, 21 December 2003 at 10:44 AM · edited Tue, 19 November 2024 at 8:28 AM
Does anyone know how to fix a figure that you have made yourself that has black bits in it? I think the black bits are caused by a problem in the normals.
iamonk ( ) posted Sun, 21 December 2003 at 10:52 AM
You can use the grouping tool to select and flip them.
xantor ( ) posted Sun, 21 December 2003 at 10:57 AM
Its not reversed normals, they are black and strange looking.
PhilC ( ) posted Sun, 21 December 2003 at 11:09 AM
You may have some polygons with more than four sides. Poser sometimes takes a dislike to them. Open the model in UVMapper and in the Tools select Degenerate, or/and/concave/collinear. If that was the problem then this should fix it.
xantor ( ) posted Sun, 21 December 2003 at 11:22 AM
thank you phil
PheonixRising ( ) posted Sun, 21 December 2003 at 3:18 PM
Here are some other possibilities. Black Facets, which typicqally are found along the rendered edges of models, also are found in other spots when a non-trianglulated polygon(square) is folded into a unusual shape that causes a render error. Nendo and Wigns have "Flatten Normal" for it. Or smoothing helps. Black Polygons are also caused by irregulal stitching where two or more non-adjacent polygons are accidently connected. In this image I duplicated and rotated the mesh four times and highlighted the same irregular polygon on each to show the odd contour. This can cause a dark render spot. This exaample is most often found in over morphed faces. But again. In wire mode, look for a line , illegally connecting the black polygon to another not next to it. Regards, Anton
-Anton, creator of ApolloMaximus: 32,000+ downloads since 3-13-07
NEW The Poser FaceInterMixer
xantor ( ) posted Sun, 21 December 2003 at 9:26 PM
Thank you anton
wyrwulf ( ) posted Sun, 21 December 2003 at 11:50 PM
When ProPack first came out, there was a lot of problems with black polys when the grouping tool was used. I don't have ProPack and don't remember the details or the fix.
