Put some clothes on your model, then go to the material editor and select the part of your clothing that you want to be lace, then load the lace as a material, er I think load the lace as a transparency. I've never done it, but that's the first thing I would try. don't forget to turn the transparency sliders all the way up. Love esther
I aim to update it about once a month. Oh, and it's free!
What kind of effect are you looking for?
"you are terrifying
and strange and beautiful
something not everyone knows how to love." - Warsan
Shire
OK, I would select the brim in the materials list, make the diffuse colour to match whatever the rest of the hat colour is. change the Transparency value to 1.0 and also the Transparency edge to 1.0, and make sure Trans Fall off is 0. Plug the lace tile into the transparency node. You will probably have to change the U_scale and V_scale of the trans map, depending on how big the tile is (I mean, how often it repeats, or if it is just one tile.) Does that help?
"you are terrifying
Shire
Try making them 0.5 each (they need to match or the texture will be stretched in one dimension.) See how it looks at 0.5 then go smaller to make the lace finer, or higher to make it "bigger". The change of scale won't show in the preview window - you'll have to render to see how it looks.
"you are terrifying
Shire
Just bought some seamless lace from the MarketPlace, but there are no instructions on how to apply them. Can anyone help? Thanks
