Fri, Jan 24, 12:43 AM CST
Subject: Vue 4.2 & P5 question
eric501 ( ) posted Mon, 22 December 2003 at 3:35 PM ยท edited Fri, 24 January 2025 at 12:40 AM
Okay, I have P5 and vue 4.2, but I install everything I buy into P4. Vue and P5 work great except for any props I might have in the P4 directory, they won't load up when I import a poser file into Vue. As far as I know it's just the props. Is anybody else having the same problem?
gebe ( ) posted Mon, 22 December 2003 at 4:14 PM
Some props from Poser doesn't import properly into Vue.
eric501 ( ) posted Mon, 22 December 2003 at 6:50 PM
yeah, so do i need to move them to the poser 5 directory? I was trying to keep from having multiple runtimes in P5.
firecircle ( ) posted Mon, 22 December 2003 at 7:21 PM
I use vue and p4/p5 quite a bit and the best way to work i have discovered is to copy the geometries and textures folders to p5. This gives vue what it needs without cluttering up the pose folders:)
eric501 ( ) posted Tue, 23 December 2003 at 8:35 AM
thanks, i'll have to try that
Blarghd ( ) posted Tue, 23 December 2003 at 4:27 PM
so whith the props your saying move them to the P5 Runtime I keep everything in my p5 and a separate runtime of my own,.. but when I imported something into vue earlier,.. a few props didnt import,.. and it changed a few of my textures,.. blarghd
firecircle ( ) posted Tue, 23 December 2003 at 8:09 PM
ok let me clarify. when vue imports using the p5 pz3 importer it asumes that the gometeries reside in the p5 runtime. If you use a number of external or network runtimes it is easier if you copy the geometeries and textures folder to the p5 resident runtime .dont move them copy them. That way you have the library structure you are used to and when vue tries to import it finds things where it expects them. I have used this with p5 and vue and p5 and vue pro without any problems.
