DAZ|Studio F.A.Q (Last Updated: 2024 Dec 26 8:06 pm)
Check through the pdf base docs. Sitting down to read myself.
-Anton, creator of
ApolloMaximus: 32,000+ downloads
since 3-13-07
"Conviction without truth is denial; Denial in the
face of truth is concealment."
I am still reading. Having trouble sleeping so I will go through it. It is under Daz>Programs>Artist Guide.
-Anton, creator of
since 3-13-07
Hey Peng! Well, I can now see the content BUT when I go to open a figure ir always says it can't find the geometry file. The geometries are listed in the content drop down on the left. scratching head.........................
In a world filled with causes for worry and
anxiety...
we need the peace of God standing guard over our hearts and
minds.
Jerry McCant
kayjay.. Here is what I have found concerning .cr2 and .pz? files. If I have a .obj or texture file referenced with the path as such :runtime:geometries: ........ I am prompted to search for the needed file. If I put in the actual path of the object in the .cr2 file such as below ... h:poser4runtimegeometries ...... then the file is automatically found and loaded without any intervention from me. If you will notice that when you are prompted for a file location the path will look something like this /runtime/geometries/ I consider that to be poor programming ( the " /" ) on the part of DAZ, sorry about that folks, I am a hugh fan of DAZ, but I also program in C and when I see something like that and I am experiencing file and directory parsing problems, I consider it poor programming. Parsing a path is basic to any file operation and there should never be a coding error in that respect. I suspect as I have stated in another thread, that when DAZ corrects what I believe to be file and directory parsing errors, then they will probably clean up a number of 'odd' bugs. BabaLouie
Hi Babalouie. Got your PM :) That sounds like an awful lot of CR2s one would have to change doesn't it? Melanie, on the left side of the screen is a content box. ODrop down say Daz Content or POser Content and I believe other imported content
anxiety...
minds.
Jerry McCant
That sounds like an awful lot of CR2s one would have to >change doesn't it? Yeah, I know, it does not sound right and I do not think that is what DAZ wants to happen, but it does seem to fix the problem for me. I was looking at the log.txt file for DS and was watching what and where it fails. It seems that DS relies quite a bit on the 'content' and poser folders for pathing instructions when importing files. This seems a bit risky to me, but I suspect it will eventually make DS a bit more bullet proof for the majority of users. Since I use mostly custom folders and keep virtually all parts of a model in that folder, it causes a problem for me. I do not much care for being locked into preset folders and paths. :) Of course this is an Alpha, and I am using W2k pro that I geek pretty deeply, so I am looking into some of the esoterical things that I have done to Win2k. But I always get suspecious when I see 'string messages' using the / in the path name. Sometimes it can indicate a programming oversight elsewheres and then again it may just be the way the error message was coded to display. Overall I am impress with DS and certaintly DS will continue to improve as DAZ has dedicated themselves to this program, I am sure they will be successful. BabaLouie
How do you set up Studio to pull in the poser files? When it first installed it searched them done and I had no problem. Closed the program ot, reopened it and nothing.All I have are the two Egyptian ones. I can't figure it out :(
In a world filled with causes for worry and anxiety...
we need the peace of God standing guard over our hearts and minds.
Jerry McCant
