Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 21 12:04 pm)
Yes , Darth is correct. I have no problem running it "sort of" in the background by just opening things on top of it. But, it refuses to cooperate if you try to minimize it...if you can minimize it at all. I use the start bar or my office shortcut bar which usually stays on top of Poser when opened.
Isn't it amazing how the same program can react so differently on different systems using the same OS? Very weird. I can't minimize while it is rendering, but I can do anything else I want, opening windows on top of it. If it's a long render (not many of those for me), I go play Doom (yes, in DOS!) while its happening, hitting the Windows key every now and then to check on progress. Dan
I've never had any problems with Poser in the background (well, OK, I have run out of memory during some renders, but otherwise...). At home I run Windows 98 (SE, I THINK, but I'm not sure). At work I run on NT 4.5something. Both at 128 MB RAM. 400 mhz proc at work. I USED to run a 266 Celeron at home, but have a 550 PIII now. But then I rarely play games while rendering (if I do, it's something lame like Freecell, or something that uses the CD more than the hard drive, like Civilization II)... I often write or read e-mail during renders though... Usually I have two or three graphics apps open (PaintShop Pro, Poser, sometimes Bryce), a word processor (Word) and America On-line open with no problem...
Hello ! My problem is to get Poser 4.0 (PC-Version) to work in the background. When I does huge animation sometimes my computer is blocked for 5h or more... When I press the windows-button on my keyboard to work with another programm, poser will abort rendering and crashes... Is there a way to get poser work in the background? My system recources must be enough... (600MHZ Athlon and 256MB RAM, Swap file on HD is 1GB fix size)... Thanks! Andreas
