Yep, Vue is a Ram Guzzler! I also agree with Richard. OpenGl is a (powerful) graphic & modelling software library, which intentionally provides only low-level rendering routines. So, that you can have more control on your graphics hardware. It has absolutely nothing to do with memory. Vue has a drawback, it does not know how to use the CPU cycles properly. So, only way to speed it up and have a well performance from it is to give it as much memory as possible. Do not neglect Motherboard's FSB; I would recommend 800 or up. Hope it helps.
I have 2GB ram and I still get the 'Out of Memory' message. Another thing to watch out for is that even though motherboards can take two or more gigs of ram, you can have problems with compatability if you don't fit perfectly matched sims. I have just had to replace my ram because it wasn't all bought at the same time and my system kept rebooting or quitting me out of programs (not just Vue). I agree with the above comments and even though E-On will not admit it, I still maintain that there is a memory leak in there - somewhere. It's a good idea to reboot before rendering a hi-res image from a large scene, just to free up as much memory as possible. Remember, the more memory you install, the more Windows takes for its own use (I have 2GB but windows takes 400MB). nish is correct also, be very careful about which motherboard you select. I think that Vue has some way to go with the Pose import side and importing multiple Poser figures seems to really eat system resourses, I now tend to do several selective renders and composite them in Photoshop afterwards. Regards.
I'm upgrading my computer system as it currently is useless for Vue or modelling or anything. I was wondering if these specifications will be good enough to run Vue 4 Pro WELL, not just averagely: 2.8 Pentium 4 processor ATI Radeon 9800 120gb Hard Drive 1gb Ram Thankyou for any opinions and advice, I apreciate it.
