Thu, Feb 13, 12:59 AM CST
Subject: Infuriating "Insufficient memory to render at current resolution" error
xoconostle ( ) posted Thu, 01 January 2004 at 3:46 PM · edited Thu, 13 February 2025 at 12:58 AM
Hello, I'm working diligently on a deadline in P4/PP today, and keep getting this error message. Actually, I have over 65 gigs of free space on my HD, plenty of virtual memory allotted, etc. etc. In other words, no legitimate reason for this error to appear that I can determine. Furthermore, it's never happened to me before, even when I was rendering at much higher resolutions. (This series of renders are being done at 1200x1200 ... hardly gigantic.) I suppose I could downsize and see what happens, but I'm wondering if anyone else out there knows of a fix for this error, or if it's actually caused by something other than what the message box indicates? Many thanks for any help you can offer. I'm just about ready to throw a brick at the monitor right now. :-)
KarenJ ( ) posted Thu, 01 January 2004 at 4:05 PM
http://www.renderosity.com/messages.ez?Form.ShowMessage=1537269 http://www.renderosity.com/messages.ez?Form.ShowMessage=1516875 There are a few suggestions in the above threads you might try. Good luck...
"you are terrifying
and strange and beautiful
something not everyone knows how to love." - Warsan Shire
fls13 ( ) posted Thu, 01 January 2004 at 4:22 PM
Give Memturbo a whirl despite what you see in one of those threads. 3D is a real memory hog, especially Poser.
xoconostle ( ) posted Thu, 01 January 2004 at 5:23 PM
karen1573, thank you for the links! So it's a bug inherent to P4, hmmm. I can't understand why I've never encountered it before, but I have several ideas for working around it, now. fis13, I've DL'd memturbo, thank you for the recommendation. I have used other apps for this in the past (MemMax and RAMbooster,) but trying another one can't hurt. I'll try to report back here if I can get the darn message to stop popping up.
queri ( ) posted Thu, 01 January 2004 at 5:27 PM
The CL fix worked for me on two computers. This one: Poser 4 Poser can't render high resolution images. Error appears "Insufficient disk space to render" After some intense investigation we believe we have a work around. It turns out that Windows NT 4, 2000 and Windows XP must be using some space for the pagefile.sys file on the same partition that Poser is installed, to render large images. The pagefile.sys is the virtual memory or temp space for Windows. An approximate minimum would 10 MB. This amount might have to be increased for more complex scenes and animations. The maximum should be 10 MB or greater. To modify the Virtual Memory: Windows NT 4 = Right Click my computer. Click the performance tab. Click change. Click the drive Poser is installed on. Enter 10 in the Initial size field. Enter 10 or more in the maximum size field. Click set. Click OK. Click OK. Click OK. You may have to restart the System. Windows 2000 = Right click My computer. Select the Advanced tab. Click Performance option. Click Change. Select the drive Poser is installed on. Enter 10 in the Initial size field. Enter 10 or more in the maximum size field. Click set. Click OK. Click OK. Click OK. You may have to restart the System. Windows XP = Click Start. Right Click My Computer in the menu. Select Properties. Select the Advanced tab. Click Settings, next to Performance. Select the advanced tab. Click Change. Select the drive Poser is installed on. Click the Custom size button. Enter 10 in the Initial size field. Enter 10 or more in the maximum size field. Click set. Click OK. Click OK. Click OK. You may have to restart the System. Poser will now be able to render up to its maximum size of 4090 pixels x 4090 pixels @ any resolution * * * Other than that-- Poser seems to want an ungodly amount of swap space on your disk so if you get under 3Gs you may have probs. Emily
pjanak ( ) posted Thu, 01 January 2004 at 11:11 PM
"Poser will now be able to render up to its maximum size of 4090 pixels x 4090 pixels @ any resolution" For win98/SE I can say that Poser 5 cannot handle HIgh res textures or renders. I have over 600meg in memory. I tried letting windows set the Virtual Memeory and then I tried setting it myself. Nope. I try to like poser but my other programs like TrueSpace/3DSMAX and more handle much higher polygon rates and very large textures with ease . The problem with Poser is that its interface is pretty. All that prettiness is eating up too much memory. PeteJ
xoconostle ( ) posted Thu, 01 January 2004 at 11:28 PM
Emily, WOW, thanks for such a thorough response. I'm sure it will help others, too. Well, the problem didn't pop up again. I think the reason it did before is that I'd been surfing the net, running several apps, all kinds of stuff prior to opening Poser. I did increase my virtual memory settings a bit more, but they were already very high, divided between two drives. After rebooting, I shut down unnecessary processes (e.g. the stuff that iTunes loads at startup,) ran MemTurbo as fis13 had suggested, and was able to complete my renders with no problem. Apparently, this really was a memory issue, although I think it's clearly more a matter of how Poser manages (mismanages?) memory than not necessarily having enough RAM and virtual RAM available.
JohnRender ( ) posted Mon, 05 January 2004 at 3:38 PM
Has a been a week since someone asked this question? Wow, how time flies. Here are (once again) the usual answers (that can be found by hitting the rarely used "Search Forum" link):
  • Upgrade to Win 2000 or XP. Get rid of Windows 98.
  • You can try CL's solution of adjusting virtual memory, rebooting, defragging the hard drive, rebooting, adjusting hard drive partition, rebooting, patching your operation system, rebooting. After you've done all this, you'll forget what it is you were trying to render!
  • Give up on P4: it won't render past certain resolutions, no matter how powerful your computer. Open the image in P5, use the P4 Renderer or Firefly/ Draft and it will render with no errors at all. P.S. I recently upgraded to a Sony VAIO, 1G RAM, 160M Hard Drive, Win XP Pro, 3.2G Pentium 4 Hyper-Threading processor. And you know what? Yep, when I try to render a large image in Poser 4, I get this error message. And the solution? Render it in Poser 5. Why should I need to adjust any system setting to get ONE program to work? Lighwave works fine. Vue works fine. Photoshop works fine. Office works fine. IE works fine. Poser 4 doesn't work fine. What does that tell you? It tells me that complaining about the errors and bugs in Poser 4 is a moot point. CL is on SP4 for Poser 5 and is in development for Poser 6. DAZ has released Studio to compete with P5 or P6. So, this is a lost cause: nobody is going to fix the bugs in Poser 4.
pjanak ( ) posted Tue, 06 January 2004 at 1:18 AM
Sounds like a future conflict of interest. DAZ studio competeing against poser and yet DAZ being the key supplier of charcters,clothes, and props. PeteJ
