-Anton, creator of
ApolloMaximus: 32,000+ downloads
since 3-13-07
"Conviction without truth is denial; Denial in the
face of truth is concealment."
-Anton, creator of
since 3-13-07
-Anton, creator of
since 3-13-07
This past October, I attended one of Lee Stranaham's Lightwave classes, and he showed us this same technique. I thought it was the slickest thing! How many times after you finish a render do you think "Dang, I wish I had made that back light a little bit stronger." Well, this technique allows you to do that. I think Anton follows a similar procedure as Lee ... set up a basic 3-point light set (Key, Fill, and Background) and render one image for each of the 3 lights. In the class, he suggested that you start in Photoshop with a solid black layer, and then layer each of the lighting renders on top of it. He also used screen mode to adjust the strength of each layer, though I think Opacity works similarly. Slick stuff Anton! Glad you brought it up. 8-)
I don't generally use alpha channels but you can do fun stuff with them for sure. Umm that's a big image there. :) Just an fyi. if you keep your image at 800 pixels wide or less, or crop it, it will prevent most people's browsers from resizing to need the horizontal scroll bar within Renderosity threads.
-Anton, creator of
since 3-13-07
I combine multiple renders all the time (see my 'snowcloning' tutorial here and at DAZ, heh), but I've never really tried combining differently-lit scenes before. Getting the shadows right might be a handful, but I'll definitely have to try that out. Thanks a lot. ;) SnowS
my DeviantArt page: http://snowsultan.deviantart.com/
I do not speak as a representative of DAZ, I speak only as a long-time member here. Be nice (and quit lying about DAZ) and I'll be nice too.
I've done this a couple of times with neat results. Do you have a guide as to what lighting to choose for the various renders ? I noticed from the first image that one light is from top, and the other two from left and right basically. I like to use this technique and change some of the layers to 'overlay' / 'multiply' or 'screen'
You can use any lighting you want really. I just picked three different light sets at random. Rally just mix your favorite ones you have. It really is a simple process.
-Anton, creator of
since 3-13-07
ohhh thanks!! also for the same pic...you can duplicate the layers make one softlight play with the opacity make another duplicate and make it......blue. not with a lot of saturation. put that {the blue layer between the normal and the soft light} and again play with the opacity, you can get some really nice effects with skin tone and depth that way. I cant wait to try your tut Anton!
https://www.darkelegance.co.uk/
Yep, been doin' that for awhile. Very, very effective. Sometimes you'll spend lots of time setting up complex lighting for a scene. At render time, you see that the shadows are just too strong in some areas, but that the brightness and positioning of the lighting is correct. Simple solution: Keep your render with the too-strong shadows, then do another with no shadows at all. Layer and adjust opacity to taste in Photoshop. Or, as Anton suggested, simply erase to the correct degree in the too-dark areas. I find this much quicker than going back and changing the shadows on multiple lights. If you've got less than 8 lights in a scene, fine. Fine-tune them by hand. Dean
NP. Always glad to share.
-Anton, creator of
since 3-13-07
-Anton, creator of ApolloMaximus: 32,000+ downloads since 3-13-07
"Conviction without truth is denial; Denial in the face of truth is concealment."
NEW The Poser FaceInterMixer
