I can recommend Traveler's Softlights which you can get free from Runtime DNA. I'm seriously considering making Softlights - Flesh 01 into my default Poser lighting setup. It seems to bring out the best in any texture; although you may prefer a white set for objective viewing of a texture. The fleshtone sets are the lighting equivalent of rose tinted glasses. :-)
The "Neutral-Bright" or "!True Globals" Complex Global Lights from the first PC Complex Global Light Set I think is the best. It is uniform and true. I think many textures come out too pale because the lights are too dark. The Complex Global Lights preserve saturation where some bright light sets desaturate as the lights get brighter. I beleive this is also why many texture packs have orange creases,hair, and details under other lighting. I have tested textures in Poser with these and find the color range to be consistant with the actual map in Photoshop. Just my recommendation.
-Anton, creator of
ApolloMaximus: 32,000+ downloads
since 3-13-07
"Conviction without truth is denial; Denial in the
face of truth is concealment."
Attached Link: Light section
I know sometimes a category will seem empty when you first click on it. The sub-category listings are bugged to display a false "sampling" of random store products while you are prompted to choose a sub-category. The Lighting category is a sub-set of Scenes. After mentioning it for over 6 months to the same people, it is sad the sub-categories in the PC are still bugged. Here is the link-Anton, creator of
since 3-13-07
Sigh. shakes head Click scenes..then click "Lighting".
-Anton, creator of
since 3-13-07
Attached Link: http://secure.daz3d.com/shop.php?op=itemdetails&item=943
Direct Link to Daz Global Lighting Pack 1. Great set of lights. I also recommend the RuntimeDNA free light sets. lots of different moods and setings to play with and see how your texture looks under different cercomstances.Render with shadows sometimes too when testing. It will show you where pale areas might turn grey if they are too light.
-Anton, creator of
since 3-13-07
When I use light I keep it short and simple - The way to use light in poser is the same way you use lights in real life. Two is all you will probably need (most proffessional photograhers use one subject light and on fill-in. In poser (any version) change the shadow mapping to around 0.150 and the map size to 1024 change the red channel to fit your preferences (I normally look for between 3- 5% more than the green or blue channel) this will give a soft early to mid morning light that is good for flesh tones. Having just two light mean that your rendering tends to be quicker in P4 - no difference in firefly if you check RayTrace on the lights instead of shadow maps. I've used this mapping professionally for a number of years.
Attached Link: http://www.poserpros.com/forums/viewtopic.php?t=17301
lululee: PoserPros has a set of free testing lights specifically to detect seams when creating textures. They are really, really good :). LaurieThis site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Can anyone tell me what the best lights are to create textures with. cheerio lululee
