Thu, Jan 9, 3:39 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 09 2:14 am)
Subject: V3 in downloads runtime in P5
Aeneas ( ) posted Tue, 06 January 2004 at 11:56 AM ยท edited Thu, 09 January 2025 at 3:35 AM
Rant, rant... Sorry, but... Well, I wanted to do a fresh install of Poser5 and this time organise everything like is said in many tuts, including the manual. As I never use the meshes that come with Poser, but only DAZ people (V3 etc...), I thought I could install these in the Downloads Runtime folder. Which I did. I installed V3 morphs (body and face) also in this runtime folder, but when I tried to load them, I have to point Poser to the correct folder and, groan, click open to each and every one of them. This is criminal! Can anyone show me a better method? Thanks!
I have tried prudent planning long enough. From now I'll be mad. (Rumi)
medmay ( ) posted Tue, 06 January 2004 at 12:01 PM
copy your !daz folder in main runtime ,not in download runtime i hope this help
medmay ( ) posted Tue, 06 January 2004 at 12:02 PM
in main runtime / libraries...
Aeneas ( ) posted Tue, 06 January 2004 at 1:48 PM
...which is what I wanted to avoid because I don't want that Poser stuff that's in there: I only work with my DAZ meshes... I know that obj files may not be moved to another location, but these aren't obj but libraries content, and this may be organised, or not? And, finally, the download runtime is for downloaded content isn't it? Thanks for your time, but this is not the solution I am looking for.
daverj ( ) posted Tue, 06 January 2004 at 2:36 PM
As long as you keep the !Daz folder in the right place I suspect that you can still keep all the characters, morphs, etc... in the download folder. It's just that they reference the stuff in the !Daz folder directly so it must be in the right place. The stuff in the !Daz folder doesn't show up in your library. It is a hidden folder that the stuff in the library must access so it can work.
evilded777 ( ) posted Tue, 06 January 2004 at 2:52 PM
Yes.... you can. I have 5 different runtimes, and the only extraneous stuff in my p5 runtime are material shaders and whatever it is in that !daz folder for the Mil3 people (and my Microcosm stuff, too). Works like a charm as long as those files are in the main runtime.
Aeneas ( ) posted Tue, 06 January 2004 at 3:25 PM
Right...so if I get it right, I can place V3, SP etc in another runtime, but I have to load the body and facemorphs into the main runtime... OK... Meanwhile I unionstalled P5, and chose "custom" for installation. THis way, I could choose not to install anything but the basic, which I reduced to Don and Judy HiRes. Thanks!
daverj ( ) posted Tue, 06 January 2004 at 4:54 PM
The way Daz does it there are two parts to the morphs. There's the stuff you see in Poser, in the library. Then there's the hidden stuff in the !Daz folder. You don't see that stuff in the libraries inside poser. It's hidden. It's referenced from inside the Pose files. So you can stick the characters, poses, mats, morphs, etc... in any runtime folder you want, including downloadruntime. You just have to make sure that the hidden !Daz folder is in the right place. So, the body and face morphs that you see in the Poser library do not have to go in the main runtime. They can be in the downloadsruntime. It's only that hidden folder (!DAZ) that has to be in the main runtimelibraries folder.
Aeneas ( ) posted Wed, 07 January 2004 at 11:34 AM
Thanks. Thefiles will probably be a variation of text-based obj files and contain some pointing to- information. Just like other obj files and textures cannot be renamed or moved without problems. Wish I had experience with P4 though... BTW: another question: In some tuts and tech notes, it is stated that only one level subfolders is permitted inside the character, pose etc folders. I noticed that in P5 (the poses for the boy for example) many more levels seem to be possible. Anyone an idea how deep this goes?
