Tue, Feb 18, 2:37 AM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 2:22 am)
Subject: New Mac OS X morph target mirroring tool
terminusnord ( ) posted Sat, 01 November 2003 at 10:09 PM ยท edited Sat, 15 February 2025 at 1:48 PM
Attached Link: http://www.poserfetish.com/morphsym/index.html
I'm working on a tool for mirroring head and body part morph targets. I make morphs in C4D, and I sometimes need exact symmetry which can't be acheived in that program. So I modify half of V3's face, and then use my tool to copy the changes to the other side. I made this program to meet my own needs, but I've decided to release it to the public since it may be useful to others as well (particularly C4D or Carrara users on the Mac).
My program is OS X only, tested through 10.2.8, and it will work on any figure file that is perfectly mathematically symmetrical (V3 and M3, Posette, but not Victoria 1.0 or 2.0 yet). V1 and V2 may look symmetrical, but there is actually a significant amount of vertex asymmetry in the OBJ files that I have to figure out how to deal with in a future release.
-Adam
MarianneR ( ) posted Sun, 02 November 2003 at 1:55 AM
Thank you! This looks interesting.
FairyRaptor ( ) posted Sun, 02 November 2003 at 5:29 PM
Wow! Thank you.
andygraph ( ) posted Thu, 08 January 2004 at 12:55 PM
Many thx for this Tool!! But when will be available for v1 or v2 ? Is there a OS9 version ?
wolf359 ( ) posted Thu, 08 January 2004 at 5:00 PM
"My program is OS X only, tested through 10.2.8,"
My website
terminusnord ( ) posted Thu, 08 January 2004 at 5:30 PM
I still use my own tool internally, but I stopped going to the trouble of releasing it due to lack of interest. I gave out 12 beta copies to people who requested to test it, and I got not a single bit of feedback, good or bad. Most folks did not even acknowledge that they ever downloaded it, tried it, and non ever emailed me about it. It's technically a carbon app, but I have no OS 9 machine here to test it on, so I can't say if it would work or not. It should, but it might not. -Adam
andygraph ( ) posted Thu, 08 January 2004 at 7:22 PM
it's possible use it with other body parts of v3 ? Anyway for v1 or v2 too will be more usefull for everybody ;-)
terminusnord ( ) posted Thu, 08 January 2004 at 10:47 PM
The problem with V1 and V2 is that the files are not mathematically symmetrical. Daz wised up with V3 and made her symmetrical. I see no good reason why the earlier victorias are asymmetrical either, they clearly weren't going for a deliberate asymmetry (it's too close for that), it's just sloppy like some of the textures are. I never got around to doing the code to make my program work with V1 and V2. It's too much work for the amount of free time I have. The logic to pair V3's vertices is a straightforward quicksort on 3 indices, but with V1 or V2 I would need either an external pairs file or some kind of slow pairing algorithm that uses increases the slop tolerance until all pairs are matched. The later solution would not only be slow, it might also produce errors with vertices that nearly overlap.
andygraph ( ) posted Fri, 09 January 2004 at 2:21 AM
but in V1 or V2, the left side have the same number of points of the right side ?
andygraph ( ) posted Fri, 09 January 2004 at 6:53 AM
So i have try it with my OS 9.2.2 and poser 4 pro pack I can open MorphSym ... ;-) I can Open the source v3 geometrie and load the morph create with amorphium .... I can export the symmetric morph BUT .. when i try to apply it to v3 i see that .... only one "POINT" morph !
