Bryce F.A.Q (Last Updated: 2024 Nov 12 7:03 am)
"The only problem I can see at this time is that the text curves backward towards the end of the word. I tried changing fonts, but it still produced the same effect. Comments?" The curving backward is due to camera angle and perspective. Try changing the camera or rotating the letters and you'll see what I mean. Elefont is a great little program, and the price is right (free). Be sure to download its sister program, Spiralizer (also free). John
Zhann: "The above is B-R-Y-C-E, in three different fonts..." Did you mean to post an image?
Contact Me | Gallery |
Freestuff | IMDB
Credits | Personal
Site
"I want to be what I was
when I wanted to be what I am now"
this is very frustrating for me, i downloaded elefont, but whenever i try to make words with it, i export them, but when i import them into bryce, bryce encounters a problem and need to shut down. i cannot figure out why this is!!! i've let it go fo now, but if anyone can help me out with this, that would be great. oh, good image by the way, but just increase the poly count on the words. the second image is much better
hmm..I've used Elefont a little, and it seems to export as .dxf (forgot to check if it does .obj..;), but Wings 3d will export in .3ds, which shows up a little better in Bryce..only headache is you have to type in the actual name of the font..;) just my 2p..and don't worry, you can try smoothing on the letters in Bryce as well..
Get Elefont and Spiralizer here; http://www.armanisoft.ch/webdesign/default.htm If Bryce doesn't want to import your dxf, use a freeware file converter, save it as obj, then it should import just fine. "Crossroads" file converter (free); http://home.europa.com/~keithr/Crossroads/index.html AgentSmith
Freestuff | IMDB
Credits | Personal
Site
