Attached Link: http://www.renderosity.com/messages.ez?&Form.ShowMessage=1419107
This tutorial should give you some ideas...Can't give you detailed instructions, but maybe a pointer as to where to look... First, Dr Geep (search for "geep") is posting a tutorial on making a Posable model. You should check it out; it's packed with vital info for anyone wanting to make a posable model. Second, the quick answers (but not the "how to"). Import your OBJ into poser. Go to the Grouping Tool (check another of Dr Geep's tutes for the lowdown) and create groups for each body part you wish to bend/morph/transform. In other words, create groups for Foot, Toes, Lower Leg, Thigh, Buttock and so forth. Save out your newly grouped model. Re import the new version (you did use a new file name, didn't you?) and go to the Setup Room. Create the bones for your model. Simply put, each group should have a corresponding bone. You will then need to edit the Joint Parameters to get the thing to bend as you require. Takes more patience than I have, that's for damn sure. That's about the size of it. I'm sure someone here will be able to give you the how/where/why/what to all this. Sorry I can't be more specific.
Attached Link: http://www.curiouslabs.com/article/archive/65/?df=1
Curious labs has a tutorial for making figures its called setup room tutorial and it is near the bottom of the page at the link.oh..sometimes it's faster to search on 'primer' than 'geep'; 'geep' gives you all of the wit and wisdom of our doc, but on other topics as well; 'primer' gives you all of the tuts..you can also find them in pdf format (well, all but the latest), at fallen city (I think it's fallencity.net..but a quick Google will help). It's Crescent's site, I believe..;)
I don't use Poser alot, but I do model and I wanted to know how I can make my models Poser ready props? I have Poser4 with Pro Pack....any and all help appreciated, detailed instructions (a step by step) gets you hugs and kisses....:) Thanks, Zhann
Bryce Forum Coordinator....
