Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 17 1:08 pm)
Can you give a side view screen shot with the joint editor open so that we can see the red and green parameters? At first glance I think you need to set the abdomen's bend red lines to more horizontal. If they are still at the default 45/135 then they are including too much of the hip. Spherical fall off zones is another option, but lets start there.
Currently the area that is blended is defined by four flat planes. By adding spherical fall off zones you can further refine the blend zone to be the intersected volume between the two spheres. Look and see how an existing Poser figure handles it. Not sure if the P4 figures have spherical fall off zones at the abdomen bend, but the DAZ millenium ones certainly do.
