That is to say...UNCHECK the "As Morph Target" if you are trying to export a figure with modifications intact (scaling, morphs, etc.) But....before you do this, open the joint editor and click "Zero Figure." Then select Body and hip to make sure all the translations (x,y,z) are 000. Otherwise, the clothing you are creating will not be in the same object space as the figure you are creating it for.
Ahhh, well, I don't have heavy set Vicky, so I can't test her, but if scaling is involved to create her, then the method I outlined won't work. The 'As morph target (no world transformations) options WILL save any actual morphs, however it will reset any transformations, including scaling, rotation, tapering etc. It will also reset any Pose changes to the default. If you are unsure whether a particular figure uses scaling or other transformations, it's safer to use the method outlined by nomuse. Sorry about the confusion Regards- Lemurtek
k i want to export vicki or other figures, with thier morphs on. i mean like vicki set to a large size so i can model for her. but every time i try vicki exports normal. what am i doing wrong?
