Fri, Feb 7, 7:21 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 06 4:35 pm)
Subject: Morph in the Parameter Dials
saheee74 ( ) posted Thu, 15 January 2004 at 9:26 AM ยท edited Fri, 07 February 2025 at 7:05 AM
I had Sara Character From Daz Products and in the face Parameter Dials there a very good action which she can close her both eyes togeather by clicking or chaging only one parameter dial.
My question is can export or use this action on other characters such as Mil Baby or Koshini or any other Poser characters ?
xantor ( ) posted Thu, 15 January 2004 at 9:36 AM
I would also like to know how that is done. Is it erc?
saheee74 ( ) posted Thu, 15 January 2004 at 9:40 AM
Wish some one can if it ERC or another application can do the same action in an easy way
ockham ( ) posted Thu, 15 January 2004 at 9:43 AM
In Koshini it's definitely done by ERC. The both-eyes dials are ValueParm channels, which control various morphs and rotations on each single eye.
My python page
My ShareCG freebies
saheee74 ( ) posted Thu, 15 January 2004 at 10:27 AM
I think I got it. I have Pose my character (blink Right and Left) Eyes then i had create this action in my parameter dial in poser. I applied my pose to my character then i went to menu bar > Object > Spawn morph target. Then i gage it a name then it was created in my parameter dial automaticly.
xantor ( ) posted Thu, 15 January 2004 at 11:46 AM
Excellent!
skee ( ) posted Thu, 15 January 2004 at 10:15 PM
NOTE: No trees were killed in the sending of this message, but a large
number of electrons were terribly inconvenienced.
FreeJack ( ) posted Fri, 16 January 2004 at 12:16 PM
You know, a long time back I saw this sort of thing in the freestuff for V2 - it consisted of basically the same sort of thing. Three morph obj files, the first two of which you added to each eye, then the third was added to the head dials which controlled both of the first two. However, this wasn't for the eyelids, but for moving both eyes at the same time from one dial, so pointing the eyes someplace became much easier. It should still be around...Just FYI...
lesbentley ( ) posted Sat, 17 January 2004 at 6:26 PM
FreeJack, there was also the VTarget thing that Bloodsong did, this exploited Posers 'point at' feature. There is also my 'Move Both Eyes at Once' a pz2 file which injected ERC and works with most characters. Rotating both the eyes (which are seperate actors) is an essentialy diffrent problem to closing both eyelids (which are part of the same actor), to close both eyelids saheee74's solution is probably the best and most simple answer. The action could be implimented via ERC if you wanted, the up side of using ERC is that it would result in a smaller file size, the down side is that ERC can suffer from crosstalk, and it would be more work to create.
xantor ( ) posted Sun, 18 January 2004 at 6:16 AM
yes I like the saheee74 method.
