In Koshini it's definitely done by ERC. The both-eyes dials are ValueParm channels, which control various morphs and rotations on each single eye.
My python page
My ShareCG freebies
You know, a long time back I saw this sort of thing in the freestuff for V2 - it consisted of basically the same sort of thing. Three morph obj files, the first two of which you added to each eye, then the third was added to the head dials which controlled both of the first two. However, this wasn't for the eyelids, but for moving both eyes at the same time from one dial, so pointing the eyes someplace became much easier. It should still be around...Just FYI...
FreeJack, there was also the VTarget thing that Bloodsong did, this exploited Posers 'point at' feature. There is also my 'Move Both Eyes at Once' a pz2 file which injected ERC and works with most characters. Rotating both the eyes (which are seperate actors) is an essentialy diffrent problem to closing both eyelids (which are part of the same actor), to close both eyelids saheee74's solution is probably the best and most simple answer. The action could be implimented via ERC if you wanted, the up side of using ERC is that it would result in a smaller file size, the down side is that ERC can suffer from crosstalk, and it would be more work to create.
I had Sara Character From Daz Products and in the face Parameter Dials there a very good action which she can close her both eyes togeather by clicking or chaging only one parameter dial.
My question is can export or use this action on other characters such as Mil Baby or Koshini or any other Poser characters ?
