Bryce F.A.Q (Last Updated: 2024 Nov 12 7:03 am)
They work great on my PC. No problems whatsoever. The interface is a tad darker. But the new Effect in SkyLab is AWESOME. (Circular clouds, better starfiled control) I havent gotten the materials yet, not sure if I want to - just a hassle to import/delete and such things. New exports are implemtented too. -James Still tweaking
Just got a corel update: here are the tweaks. "The patch includes new mapping modes such as Sinusoidal, World Front, World Side, World Cubic and Object Cubic. New import/export filters are also featured in Bryce 4.1, including X (DirectX 3D), the Microsoft 3D file format used primarily by game designers. The new patch also introduces Custom Starfields, which can be used to represent the stars visible from earth. Until now, starfields in Bryce were only able to be generated randomly"
Softsnow, same problem as you have - the so-called "custom starfields" are not working per their instructions in their Readme file. In addition, the interface is quite a bit darker and contrast seems way different than previous version. I think they messed with or messed up their gamma settings. Overall, a very disappointing result ... for me at least. Just one more reason to do more and more of my landscape work with Vue d'esprit I guess. If Vue ever gets the transparency map mess solved (or I ever figure out how Vue is supposed to handle transmaps), I'll do everything in Vue. Till then, I guess I go back to the version of Bryce before this so-called "update."
Mine installed okay but I' cant seem to get the starfields either. I mentioned the gamma in the first thread , I'm glad I wasn't just going crazy. DigitalArtist > I havent gotten the materials yet, not sure if I want to - just a hassle to import/delete and such things. New exports are implemtented too.< Are these "New" prestets?, or just the new volumetric materials from the Previous update? Hawkfyr
“The fact that no one understands you…Doesn’t make you an artist.”
Hawkfyr, no, you're not going crazy. ;) The gamma is definitely messed and it gives the whole screen a garish, almost "Martian" look. Hideous. DigitalArtist, Bryce 5 cannot be much more of a joke than this so-called update. I think, at this point, the best we can hope for is that Corel does tank and someone picks up Bryce from the selling of assets that knows the potential of the program and how to actually "update" it. From this "update," it appears they were simply looking for an excuse to get Corel on your screen instead of MetaCreations. I guess I'll be reloading the original Bryce 4.0 and the pre-Corel updates over the weekend. What a waste of time.
Don't do what I did: I couldn't get 4.1 to load, and Corel's direction recommended doing a clean load of Bryce 4. I did that without thinking, and I saw all my custom materials and skies get overwritten... Oh well, I can just open all of my old Bryce files and rebuild the library, its just going to be a lot of work. I should have copied the material and sky libraries to a different directory first.
Howdy MacIntosh: I had to Reinstall 4.0, I did it on a different drive-I will keep Meta's 4.01 around for awhile. I was unable to see comets-except when I loaded a Sky I made in 4.01 with comets. Susan Kitchens suggests setting the star intensity to 1000 otherwise the constellations get swamped out. I have not looked at the prerender options OpenGL, Sree, etc yet. I had Poser 4.01 crash before so I am not certain that the Bryce 4.1 glitches I have seen were not carry over from memory corruption that already occured. I have been absent for many months for repetive motion stress relief-but I am back and will report any bugs! Anyone know when the S.Ktichens book is expected? Eric
Welcome Back Eric, I believe the book is due to be released this month::Fingers crossed:: Please let us know if you also lost your open GL,Sree 3D,etc. options. we're tryin to establish a pattern or see of it just plain "Got lost" in the update. Thanks And again Welcome Back Hawkfyr
Wow. Well I posed the Dragon. Chose export obj, selected all the options EXCEPT export as Morph target. My sluggardly ole G3 whirred and hiccuped for a minute. Then I found the dragon.obj and imported into Bryce 4.1. I then performed the usual operations to import the texture. What version of Poser are you running? I think you might have to update to 4.02.1.1.8 or 4.03 to make it work-unless you already have? I may have to go back and try a few others now and see if I have any problems. I'll get back to you if I do. Eric
Wow. Well I posed the Dragon. Chose export obj, selected all the options EXCEPT export as Morph target. My sluggardly ole G3 whirred and hiccuped for a minute. Then I found the dragon.obj and imported into Bryce 4.1. I then performed the usual operations to import the texture. What version of Poser are you running? I think you might have to update to 4.02.1.1.8 or 4.03 to make it work-unless you already have? I may have to go back and try a few others now and see if I have any problems. I'll get back to you if I do. I wonder if the memory limit is the problem. I cant make Poser 4 work reliably without giving it at least 200 MB of ram-with about 300 Mbytes set in Virtual memory. That is REALLY slow sometimes but otherwise Poser crashes without warning. It may be a memory limitation. Try exporting a really simple model like one of the P2 dudes. But only AFTER closing Poser (if you had been using it already) and reopening. I find it has a memory leak and does not really let go of memory once it uses it. Eric
Anybody build anything with the new patch from Corel yet? Just curious what the new tweaks look like... (downloading my patch now)
