Hi no the thread from william t B below says to create morphs from each of the groups save them then re-apply them to a blank v3 which is what i've done I think. what I'm actualy trying to do is convert the v2 elf pricess from BVH so that I can use them for V3 or S3 Not having much succes though. thanks Dave
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1616219
Here's a link to Spike's tutorial by the way. I assume this is happening at Step 1 - number 8: "Load a Blank V3 and load each group's morph target that you just created." ? If so, the problem would lie in the morph target creation - either the spawning or the export. Did you check *only* the "as morph target" box? I must say, when I've made mannequins, I never bothered with having lots of groups; I just used the entire body with the target body applied to it as a morph. This is how Lord Nakagawa's V2 -> V3 mannequin works. The resulting mesh is all grouped as "hip" to keep The Tailor happy, I suppose. Better not deviate too far from the published method at this point, though.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
