Yes, of course, Vue has bump map features. Double-click on a material in the material preview window. This will open the material editor. Click the BUMPS tab. Now you may right-click inside the Bump production window and load an existing function in selecting "load function" from the scroll down list. But you also may use any of your bitmaps as a bumpmap. In this case select "EDIT FUNCTION" from the scroll down list. This will open a new window, where you have to select MAPPED VALUES. Then click the PICTURE button that becomes visible and load any greyscale or even color map. You can resize your bump map in there too.
I have problems when setting preview to one of the open GL possibilities. When i move an object it moves but the object is also still visible in the old possition. Is it a problem with my graphic c ard nvidia g force mx/mx 400 or is ther a settin in vue that i should change?
