Pam, this is essentially an ortho-textured figure. You actually remapped the head and body. What this means is that the facets at the sides of the body and head will be textured edge on. Imagine spray painting a canvas, whose surface has been rotated 75-85% away from you. Should work fine for head on shots. I have an alternative, that you may wish to look at.
One way to fix that is to grab the vertices on the edge and pull them out, but this gets to be a lot of work real quickly, I wish UV Mapper had some kind of a zoom. It is really hard to get the right ones too, as they are almost on top of each other. That is how the original maps are, though, in effect - but I'm sure it was done by a high-end program, not manually.
