Wed, Nov 27, 9:50 AM CST
Subject: How to keep different hair objects stay where they are while I pose my figures?
teyikung ( ) posted Sat, 24 January 2004 at 8:24 AM ยท edited Wed, 27 November 2024 at 9:44 AM
First of all I apologize if this is an often asked question, but I am really at the end of my wits (when coming to Poser, there's not much there, anyway...) trying to keep different hair objects (in either the format of CR2 or HR2) stay where they are while I pose the models... Should I use the figure parent setting function (when it's a .CR2 file), or simply point at the figure's head (when it's an .HR file), or there's some other way to do it? And, how can I save a figure with proper conforming features? Many thanks in advance for any help... Teyi
SamTherapy ( ) posted Sat, 24 January 2004 at 8:40 AM
You can either Conform them to the figure, or Parent them. Sometimes it's a good idea to Lock the hair, too.
lesbentley ( ) posted Sat, 24 January 2004 at 9:27 AM
Try this: Select the hair, from the Object menu Lock Actor.
teyikung ( ) posted Sat, 24 January 2004 at 9:45 AM
It works! Thank you so much! Now I can go to bed... ^_^ Teyi
maclean ( ) posted Sat, 24 January 2004 at 9:45 AM
If your hair is a prop, applying poses to the main figure can often send the hair flying off the head. The easiest way to restore it is to use ctrl-e (Edit> restore element). After you use 'Lock actor', it'll stay where it is. mac
Strixowl ( ) posted Sat, 24 January 2004 at 12:35 PM
Damn!! I just now find this out. Will save me hours of FRUSTRATION!! Than you :-)
Spanki ( ) posted Sat, 24 January 2004 at 1:26 PM
BTW, the reason the hair flys off - is because when you save a Pose, the hair (prop) pose information is saved too, but it may be a different hair prop than you were using when you last saved the pose. If you are selling (or giving away even) a pose set, you should not have any hair attatched when you create the poses, or manually go in and remove the additional pose info.
Cinema4D Plugins (Home of Riptide, Riptide Pro, Undertow, Morph Mill, KyamaSlide and I/Ogre plugins) Poser products Freelance Modelling, Poser Rigging, UV-mapping work for hire.
teyikung ( ) posted Tue, 27 January 2004 at 2:57 AM
Many thanks again. All of these information have saved me hours and hours during this couple of days... ^_^ Teyi
