Dug it up in case anyone was interested:
The Legend Of The Dogwood Tree
When Christ was on earth, the dogwood grew
To a towering size with a lovely hue.
Its branches were strong and interwoven
And for Christ's cross its timbers were chosen.
Being distressed at the use of this wood,
Christ made a promise which still holds good:
" Not ever again shall the dogwood grow
To be large enough for a cross, and so
Slender and twisted it shall always be
With cross-shaped blossoms for all to see.
The pedals shall have bloodstains marked in brown
And in the blossom's center a thorny crown.
All who see it will think of me,
Nailed to a cross from a dogwood tree.
Protected and cherished this tree shall be
A reflection to all of my agony."
This is one really incredible looking tree! If I recall, doesn't x-frog have a polyon reducer that's sorta designed to help out? Couple suggestions, as well (and I do want this, no matter how big, lol): for trans flowers, two flat plane rectangles at right angles to each other and sligthly curved, maybe double sided , with a half sphere in the middle for the thingies. This would still be heavy en masse, but would definitely help for more distant renders. And could you release just the flowers alone, as well? Those are wonderful! Truly wonderful!
XFrog does use a slider to help reduce poly counts. This is at about 10%...and runs about 88K. At 100%, it's over 500K....ugh. As far as the flowers in renders this size, a flat alpha plane would probably suffice, since it's hardly got any depth to it as it is...However, considering the reduced state, it might have already been reduced to that by xfrog itself... XFrog also has a limited set of primatives, so some of those things might not be possible...I'll lookinto simplifying it a bit more, though. eric
