Mon, Dec 23, 5:46 PM CST
Subject: Need explanation of the "focus" on camera settings
dlk30341 ( ) posted Sun, 25 January 2004 at 7:02 PM ยท edited Fri, 08 November 2024 at 5:35 AM
I understand what it is used for, but how do you judge the distance based on the number...I have Blur set at 3 & the focus is at 100, which I assume is the preset number there. I guess I don't get/understand the distance thing . What exactly is focus = 100, is that like equivelant to feet/miles???? TIA
nish ( ) posted Sun, 25 January 2004 at 9:47 PM
Focus works just like a normal camera. The presetting I believe is 35mm in Vue. If you take a real camera and set the focus at 35mm; the way the picture would have come up in the camera will come up the same way in Vue. So, naturally when you set the focus at 100 you are just bringing everything closer (to be precise VERY VERY close)! :-) And blur is just to create more depth. Just like when you adjust your camera focus at some point the picture becomes a bit blurry (too close or out of focus). Hope it helps!
gebe ( ) posted Mon, 26 January 2004 at 5:02 AM
Click the link here and go to my utorials. See "Deepth of field". This is for Vue 4 versions, because in Vue Pro you can be much more precis. Guitta guittalogo.GIF Tutorials for Beginners
dlk30341 ( ) posted Mon, 26 January 2004 at 9:03 AM
Thanks a bunch!!! Should have gone there in the 1st place ~doh~
