Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 05 9:59 am)
How big and/or complex are the scenes you are rendering? Are you using Firefly? I haven't even touched Firefly on my P5 yet; still using the P4 renderer. However, the consensus is that Firefly can be painfully slow.
Not likely to be the graphics card - if I remember correctly Poser uses system memory and doesn't make use of graphic card memory. Check to see if you have unnecesary background programs running at the same time as Poser. There are object tracking options in Poser - try a different setting and see if that helps.
Biggest single reason for Poser5 to run slow is that texture files in many downloads, both free and sold, are not aligned properly with the library items they go with. Run CorrectReference, a free utility here, on all your library items. CR will optimise the linkages and identify any missing files.
Gordon
I have computer with 64mb Nvidia Graphic Card, 512mb sdram, p4 1,7 cpu but poser 5 works very slow on my computer what would be the problem. I also use 3ds max and in that i use more complex objects but there is no proble do you have any comments for me!
