Sat, Nov 9, 5:16 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 09 3:34 pm)
Subject: .obj Morph targets withe Poser 5 MAC OSX BIG PROBLEM
eggi ( ) posted Tue, 27 January 2004 at 3:23 AM · edited Sat, 09 November 2024 at 5:15 PM
Hi, I have a big probling using .obj files (morph targets) with poser 5 for MAC OSX. Someone in this forum gave me the following tip: 1 load the figure. 2. Turn IK off. 3. Then go to Windows: Joint editor and click the "Zero Figure" button. Close the Joint Editor window. 4. Next you choose File: Export: Wavefront.obj Then choose Single frame 5. Next you'll get the Hierarchy Selection. Click Universe to deselect it and then click your bodypart (or rather the little square in front of the name). You can only do one bodypart at a time. 6. Then you'll get the Save as dialog. Give it a suitable name so you'll remember what it is. 7. Next you open this file in your text editor and exchange the v-lines. I have make that intructions. I opened the obj file from my figure in athe OSX own text editor and cut all v-lines out and paste the v-lines from the morphtarget into it. If i load the morph onto my figure, nothing in the propheties window happened :-(( has someone another idea how to import obj morph targets into poser 5 for MAC OSX? Please do it step by step, because Im a newbie and english was not my favorite lesson in school ;-) Greets eggi
estherau ( ) posted Tue, 27 January 2004 at 6:03 AM
Hi eggi, I've got a mac OS x and I'm fairly new to poser 5 myself. I can't answer your question although it sounds like something I should try and do too, so anyway I just thought I'd say hello and I'll wait and see if anyone answers you. Bet you wished you'd paid more attention too your english lessons now hehe Love esther
MY ONLINE COMIC IS NOW LIVE
eggi ( ) posted Tue, 27 January 2004 at 6:29 AM
OK lets waiting, I hope someone takes the worm ;-) Ive sleeping to much at the english lessons, my teacher was a very boringly man :-))
MarianneR ( ) posted Tue, 27 January 2004 at 10:37 AM
What happens when you load the morph target that you edited? Does Poser put up any message? I've noticed too that when you load a "squished" morph target (without the lines starting with vt and f) absolutely nothing happens, but if you follow the instructions it should work and you get a new dial with the name "shape1" (or any other name you chose).
eggi ( ) posted Tue, 27 January 2004 at 12:00 PM
Hi MarianneR, thanks for reply. After I m ready with the settings in Poser Poser ask me how to save the wavefront obj. (after choosing single frame) In this window, what I have to choose? I have paste all v-lines. But there is no shape in the prophieties :-(( Poser gave no message to me! Nothing happend I have just cut out the lines starting with v. I havent deleted the other settings! For testing I have tried to import the obj file in Poser. But he doesnt import it. He gave me an error message. I dont know what Im doing wrong! PLEASE HELP ME! eggi
MarianneR ( ) posted Tue, 27 January 2004 at 12:22 PM
I'll try to make a little walkthrough. I'm using a head morph for Victoria 2 here. After choosing single frame choose the bodypart here.
MarianneR ( ) posted Tue, 27 January 2004 at 12:29 PM
In the next dialog box give the file some name you'll remember and put it someplace where it is easy for you to find it. And look at the picture for what to put in next dialog box.
eggi ( ) posted Tue, 27 January 2004 at 12:37 PM
Ok thats mine:
MarianneR ( ) posted Tue, 27 January 2004 at 12:42 PM
Now open your exported file, say it's named "vickihead.obj" and you'll see something like this:
InternalName: head:2
ExternalName: Head
Num verts: 10041
Num sets: 40460
Num elems: 10264
Num tverts: 11777
Num tsets: 40460
Num tElems: 10264
v -0.000616282 0.646023 0.03569
v -0.00209108 0.645882 0.0354756
.... (lots of lines that start with "v" )
vt 0.516514 0.076071
vt 0.515097 0.072126
vt 0.519675 0.113336
... (and a lot of lines that start with "vt")
vn -0.109033 0.982014 -0.154143
vn -0.0199377 0.662191 -0.749069
vn 0.00934567 0.993223 -0.11585
... (many lines like these too)
f 5163/1098/5163 5141/1097/5141 5140/1209/5140 5145/1091/5145
f 52/1176/52 35/1094/35 34/1208/34 36/1196/36
... (and then lots of lines starting with "f")
Now open the file with the morph, say it is called "morph.obj", and it will probably only have lines starting with "v" in it.
Now delete all the lines in "vickihead.obj" that start with "v" (not the ones starting with "vn" or "vt".
Select all the lines in "morph.obj", copy (command +c) and paste them into the "vickihead.obj" where the lines were that you deleted.
Save the "vickihead.obj" file. It's best if you give it a new name so you can try again if you made a mistake.
MarianneR ( ) posted Tue, 27 January 2004 at 12:43 PM
Oops! Crosspost :)
eggi ( ) posted Tue, 27 January 2004 at 12:47 PM
Ooops :-) The chaos is perfect :-D Belive me, I have make all your instructions! Nothing happend :-( If I import the obj file thats my result:
eggi ( ) posted Tue, 27 January 2004 at 12:49 PM
that is my breastmorph for mayadoll ;-)
MarianneR ( ) posted Tue, 27 January 2004 at 12:53 PM
Is this a morph you made yourself? In which program?
mateo_sancarlos ( ) posted Tue, 27 January 2004 at 1:51 PM
It's a bad morph. It shows translation and bad vertex order. it appears to be a problem in the modelling program, not Poser. My guess would be C4D.
MarianneR ( ) posted Tue, 27 January 2004 at 1:58 PM
Yes, I've tried with a head in C4D without the morphloader plugin. The result was scary :)
LeeMoon ( ) posted Tue, 27 January 2004 at 5:47 PM
Well, I'm not sure if this will help or not. I'm running Poser 4 under Classic in Mac OS X. I make my morphs and then export them as .obj files just as MarianneR so nicely illustrated in message 6 and 7 above (thanks MarrianneR!!) Next, I select the body part in Poser and do a command i to get the body part properties. Then, click on the button named "Add Morph Target." You can then select the .obj file you previously exported and change the parameter dial label at the same time. Click OK and if all goes well, the new morph will be applied to the body part. Again, I'm not sure if this works in Poser 5 or not.
Ghostofmacbeth ( ) posted Tue, 27 January 2004 at 8:02 PM
I know that Pro Pack had a glitch in edited objs on the Mac that if the stripped (v line) was taken out it didn't work and I think that I read it was never fixed in Poser 5 so that may be your problem.
eggi ( ) posted Wed, 28 January 2004 at 12:57 AM
@ Marianne No the morph is from the freestuff section! I have this result with other morphs, too! But thank you very much for trying helping me!!! I think I am just to dump for morphing in P5 :-(( In Poser 4 unter MAC OS9 I had no Problems! @LeeMoon, I dont have the classic OS on my MAC anymore! Ive deleted it as I installed Panther 10.3! @Ghostofmacbeth sometemis it is very hard to be a macuser! Thanks to you all eggi
MungoPark ( ) posted Wed, 28 January 2004 at 12:57 AM
Do it like this: Zero figure completely Export the body part as .3ds Import into C4d - set import settings scale to 1000 Export from C4D as object, set scale to 1000 (not -1000!!!!!) Import into Poser , via Add morph target This works for me perfectly on the Mac since OS to OS 10,3 Mungo
eggi ( ) posted Wed, 28 January 2004 at 3:05 AM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=1637415
Hi, please look on the atached link!
eggi ( ) posted Wed, 28 January 2004 at 4:18 AM
http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=1637440
