Forum Moderators: Staff
The New 403 does not save the menu positions on exit, I called curious labs, it is a glitch and they are aware of it, also if your doing animations create your own lights and boost the shadow map resolution to about 80000, this will give smooth shadow edges, poser uses maps verses raytraced and you have to boost the maps past 1024 to get non choppy shadow edges, also turn the shadow darkness down a bit, keep in mind the the exaggeration poser puts in the keyframes for natural movement, sometimes you have to change the keyframe to linear to stop the overcompensation.
Sorry, Oarman ...the lights that come up with the standard settings wont go past 1024 for shadow mapping, you have to create lights and get rid of the ones that normally come up. once you have your new lights they have more controls than the standard, shadow maps can go to 8000 and more if you have enough ram, ive got 64 meg and the maps top off at about 9500, yes this does take a lot of memory but poser isnt a ray tracer and uses mapping, you have to boost the maps to get superior results, I am looking into the poser to truespace plugin so I can render my poser anims in truespace wich is a raytracer and has bigtime render output. hope this helps... later
Light dials.. once your new spot is created you have dials for angle start,angle end, distance start,distance end,SHADOW,MAP SIZE,x rotate,y rotate, ect. hope this helps you oarman. by the way I am dumping poser 4.3, im going back to the ghost effects version, here is a list of problems.. BVH motion does not work correctly SAVE STATE doesnt work and is too annoying LIPSYNC software im using doesnt like the curious labs update JUST ALL AROUND not comfortable with the new software maybe in newer versions curious labs will do a better job but for right now ghost effects version is the best, ive used all versions extensivly and this is my opinion. no trouble with the previous versions. good animating everyone..
Two questions. Has anyone noticed any glitches or problems witht he 4.03 upgrade for Poser? I ask because I haven't installed it yet and want to be prepared for whatever horrors might arise. Has anyone had any problems with making movies in Poser? On two different occasions I've rendered two different movies adn they've come out pretty 'choppy'. Tried rendering smaller sections, tried just rendering single elements (paste them all together in Premiere later) and had no luck... Any ideas on that? Any solutions?
