Mon, Dec 23, 6:20 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 22 10:18 pm)
Subject: Transmapped pony-tail in Bryce
pa902 ( ) posted Fri, 08 September 2000 at 10:10 PM ยท edited Mon, 23 December 2024 at 5:44 AM
Does anyone know how to get the Transmapped pony-tail to work in Bryce. I loaded the trans map for the transparency channel -it didn't work. Anyone know how to do it? The ponytail object is two parts-do you apply the texture to each part individually or select both parts and then apply the texture. It really looks like crap in Bryce-Has anyone installed the corel upgrade for Bryce? What do you think of it?
Roshigoth ( ) posted Sat, 09 September 2000 at 12:39 AM
Here's how to do it: Texture each part separately... Select the tail part, open up the material lab, pop up the texture and choose TailTX.jpg for the texture and TailTR.jpg for the transmap. Then click the little down-arrow near the top right, and choose Blend Transparency. Then click the little dot for Transparency under the channel that holds the tex/transmap. Make sure Transparency is set at 0. Repeat for the head part, using HeadTX.jpg and HeadTR.jpg. That should work. Let me know if you have more problems. =) Rosh
Lunaseas ( ) posted Sat, 09 September 2000 at 7:13 PM
Can you do this in Bryce 3d too? I haven't played with Bryce much, but that's the version I have.-Kirsten
Roshigoth ( ) posted Sat, 09 September 2000 at 7:41 PM
Should be able to. Not sure. You might have to rotate the texture or something (if you do, just rotate it the same as you do for normal poser textures). Rosh
pa902 ( ) posted Sat, 09 September 2000 at 8:14 PM
Hey I got it to work great! Thanks alot!
pa902 ( ) posted Sat, 09 September 2000 at 8:15 PM
