Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 22 7:36 am)
If you have Poser 5 you can create multiple runtime folders on your drives. If you have Poser 4 you must move the complete installation to your new drive. Mazak
I have several runtime folders that I switch in and out of the poser I am using. it CAN be a pain in the rump as the bigger runtimes take upto and hour to move. BUT it can and does save space and the problem of searching for things.{I have one folder for V3....one for V2 etc etc this way all their cloths mats props are with them. no searching for ever through a HUGE list} also usually you have to close poser down to move one in and one out. BUT as I said it does save space as I keep the other runtimes on another drive. I am using poser pro. {P.S. also keep backups on disk. trust me just do this}
https://www.darkelegance.co.uk/
the other runtimes are not on the same drive. and I have no problem with poser opening the one that is in the poser folder. it only opens the one that is in the poser folder in programs. the others I keep in a folder called"My poser libraries" then in sub folders of"V3""V2" and so on. I guess that is why poser doesnt look for them
The list at the side containing the runtime, if you click to go up a level you will see two folders, one for Poser5, one for downloads. At the very bottom of the list there is a plus and a minus sign, when you click the plus it gives you a browse list and you just locate your other runtimes and click ok. Works like magic and I've discovered since I did this a couple of days ago that Poser seems to be much more stable with the runtime on the other drive. 8) Catlin
My c: drive is toooo full thanks to all the goodies I've added to my runtime. Is there a way to move the entire runtime folder to another drive on my computer, and make Poser find it? Where are the preference settings in Poser to make this happen? Thanks!
