Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 20 7:29 pm)
In Truespace it goes like this:- Right click the Paint Object icon In the Shaders window left click the colour shader, then in the popup window select texture map. Now right click the colour shader, now in the texture map popup window brows for the texture map. Lastly left click the Paint Object icon to apply the texture. Hope this helps. I use TS for all my modeling. PhilC www.philc.net
I still have better luck when I make sure that all props (including hair) are "un-parented" from any figure before exporting. Also, I, if I'm not going to bring the figures back into Poser, I always choose 3DS as the export format rather than OBJ, because Truespace supports textures for 3DS import. If you do this, you will need to convert your textures to TGA and save them to the same folder as the 3DS file. If you do everything correctly, the 3DS file should import fairly much intact, however, you have to recreate any bump maps and/or transparency maps as they are not supported in the import. -SMT
Anybody know how to? Thanks AL
