Vue F.A.Q (Last Updated: 2024 Sep 26 4:27 pm)
Well i had just recently did an image that used a few terrains, a water plane about 6 or seven bush trees and i also imported a horse which i then gave them water materials with a high refraction index. Now the amount of polygons was in the "red", but still handled pretty good until rendering time came. So maybe use lots of terrains and trees and also water with high refractive index.
My last image (not posted yet) just has one character, a handful of objects... very simple scene. However, it has a dozen of lights, most of them quadratic with soft shadows, a volumetric atmosphere and two large volumetric spotlights. Time to render in Broadcast mode, in 3500x2600 pixels - 57 hours. Same scene in screen resolution - 6 hours. On the bright side, my biggest scene (The raft of the medusa) had 17 Michael characters imported into Vue with multiple props. It required some juggling with layers but it was workable. The trick is to group parts of the scene in layers and just make them invisible if you don't work on them anymore - it makes Vue a lot faster for very complex scenes.
Just crank up the resolution of the terrain meshes. I notice that Vue automatically creates a pretty high mesh with a lot of polygons. A lot of people then flatten their meshes to indicate fairly flat ground, or a path or something, but they don't reduce the "resolution" of the meshes, even when they are using materials with 'noise" to generate the acutal surface appearance. So, many people's scenes have an unnecessarily high polygon count (red numbers). It follows that you could just go in and crank up the mesh resolution without changing any real features of your scene. Mesh resolution probably is the single greatest source of polygons in anybody's scene.
I am so envious, you're a lucky man MrB. I'm so envious, I've just had a look at the specs of that case and it's incredible, I reckon I'll be having one of those Lian Li cases. Oh there're in stock too, and the store is only 15 miles up the road. You're a bad man tempting me like this. Quick question, what Graphics card are you putting in?
nice comp man, btw the winxp 64 amd edition sounds mighty promising, ive seen some serious performance increases, of course it depends on what apps you run aswell. looking forward to hearing your vue benchmarchs with it :) ive already set up a couple of amd64 comps and im mighty impressed by it, but im waiting building my own until they release the new motherboards later this spring.
Still waiting....grrrrrrrrrr.... In the initial box, I'm just slapping in a GF4-MX440 card with 64 megs of DDR. The GF4-TI4400 I have in the current box will get shifted over, and the cheapy will get placed into the current box(which will get relocated into the rendergarden, and let me use the Athlon 700 as a DX7 DOX-Win9x box for games and such). I'm going to be doing multiple installs of the OS, seeing how it performs on the IDE, RAID, and SATA controllers. I'm sure there will be driver issues, and the drivers out now are all 32 bit code, but that is what the Internet is for. Sentinal; If you think the case specs are bad, they have an insert that lists all the aluminun faced goodies you can put in it. About the =only= thing that won't be shiny is when I move my Audigy 2 over, and the breakout box goes in. All you have to do to use the CD fronts is remove the tray end piece, and snug the device against the new end, so the button contacts the end button on the drive. The floppy requires you to remove the face and button, but it snugs just fine, as well. About the only thing I would change is getting the PC-75 case, as opposed to the PC-70; the former has casters on it.
I've seen the bezels you can get for the cd and floppys, didn't know they came with the case though as the supplier I've got in mind lists them as accesories. Having a look at the different cases I'm drawn towards the PC6070 for it's quietness. Thanks for the info, Oh and your pics are better than the manufacturers ones I've seen :)
Thanks, and an update. She lives! I was having a royal PITA on boot....as in she wouldn't. What it finally turned out being was the daugther card that provides extra power smoothing. Apparently something there isn't right. But Kingston ValuRam seems to work so far with the Gigabyte board (it boots). Now comes the Win2k install, then the upgrade to XP 64. It seems that a lot of vendors have been waiting for the OS release. VIA has beta Hyperion unified drivers for XP-64, as does Nvidia and ATI (although I have a very cheapy GF4Mx440 for testing purposes), and Sun has released a beta of 64 bit Java, both runtime and SDK. Oh, and the bezels were easy to adapt. The floppy one requires you to remove the faceplate and button (and it's easier to do with a disk inserted), then place it into the frame and butt it against the bezel. The CDCVC bezel only needs the end of the tray removed, but you have to remove the bezel, insert the drive, reattach the bezel, then position the drive so that the plastic button rests on the drive tray button. The next test is gonna be if the OS installs correctly....
I'm getting ready to build my Athlon 64 box (hopefully starting tomorrow), and I'm wanting to create a scene, or set of scenes, that I can render on the current box, save, and then render on the new one to see how the performance is, and if there are any potholes the new technology might fall into. Any suggestions on just what kind of scene(s) could make Vue 4.2 and VuePro scream in agony? Already plan to do a multiple Poser import (probably with Dina, as she has an even higher polycount than the Unimesh does), a single figure with one of Steffy's hires texture sets. That handles import issues regarding memory, but doesn't get into what Vue itself can do...
