Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 21 12:22 am)
For one thing, you should be sure that the internal names for each FloorTile are entirely different. In the cr2 you'll have a section that begins something like this: actor FloorTile1_A { name FloorTile01 on bend 0 ..... The name in the first line is the internal name, and it needs to be different for every instance, even if the external name (on 3rd line) is the same in both files. If this doesn't help, I can rig you up a Python script that will do the job from a different angle!
My python page
My ShareCG freebies
Thanks ockham, but if I do it that way, I have to make separate SET files for all the Elements/Figures. The SET files work with the actor. Example: SetFloorTileAllOff.pz2 { version { number 4.01 } actor FloorTile01:1 { off } actor FloorTile02:1 { off } } This works for multiple instances of the same figure, but not in case described above. It seems to me that Poser is going through the list of Figures loaded and switches off ONCE when it finds a fitting actor. One idea I had is to put in ghost parts for items that lack FloorTile02. Does this make sense?
Just for clarity: Are you making the internal names in the CR2 files entirely different? For instance, in the first CR2 make the internal name FloorTile01XYZ, and in the second make it FloorTile01ABCD. Using Python scripts is easy. The Poser manual covers it fairly well, but for a one-picture look, go to my website ockhamsbungalow.com/Python and click on the first line, How to Use Python.
My python page
My ShareCG freebies
No, I do not make the names different. I have a lot of parts in the cr2 files that can be switched off separately. These parts are named (actor!) equally in several figures, so that I have one SET file that works with all cr2 files. Example Figure 1: { version { number 4.01 } figureResFile :Runtime:Geometries:TFX:ClawHall:ClawEdgeSmall.obj actor BODY:1 { } actor EdgeCore:1 { storageOffset 0 0 0 geomHandlerGeom 13 EdgeCore } actor CeilTile01:1 { storageOffset 0 0 0 geomHandlerGeom 13 CeilTile01 } actor ColBase:1 { storageOffset 0 0 0 geomHandlerGeom 13 ColBase } actor FloorTile01:1 { storageOffset 0 0 0 geomHandlerGeom 13 FloorTile01 } Figure2: { version { number 4.01 } figureResFile :Runtime:Geometries:TFX:ClawHall:ClawWallRail.obj actor BODY:1 { } actor RailCore:1 { storageOffset 0 0 0 geomHandlerGeom 13 RailCore } actor RailLeft:1 { storageOffset 0 0 0 geomHandlerGeom 13 RailLeft } actor RailRight:1 { storageOffset 0 0 0 geomHandlerGeom 13 RailRight } actor FloorTile02:1 { storageOffset 0 0 0 geomHandlerGeom 13 FloorTile02 } actor FloorTile01:1 { storageOffset 0 0 0 geomHandlerGeom 13 FloorTile01 } Thanks for the hint on Phyton, I knew I had to read the manual one day...
I can write a script quickly that should do the job; in this case I think Python will behave differently than the PZ2. As I imagine it, you'd want a button that toggles FloorTile01 off and on in the currently selected figure, and another button that toggles FloorTile02 off and on in the currently selected figure. Does that correspond with how you need to operate?
My python page
My ShareCG freebies
You want to switch all FloorTile01 at once, or just the one in the selected figure?
My python page
My ShareCG freebies
Oh! Sorry. I just assumed you were using Pro-Pack. If you're in plain Poser, Python won't work.
My python page
My ShareCG freebies
Isn't cross-posting fun? Incidentally, this problem is one case of what's usually called "crosstalk". It was solved in Poser 5, at least for some cases. I don't know if this particular branch of the problem was solved.
My python page
My ShareCG freebies
I made 2 characters. Figure 1 has a group FloorTile01 and Figure 2 has two groups FloorTile01 and FloorTile02. Now I have a generic SET (Pose) file which simply hides the floor. The idea is that I can use it on Figure 1 and on Figure 2. So it simply hides both FloorTiles which is no problem when I load one of the Figures to the scene. Now I loaded Figure 1 first and Figure 2 next. I selected Figure 1 and applied the SET (Pose) File. FloorTile01 from Figure 1 vanished as expected, but FloorTile2 from Figure 2 also vanished. I didn't expect that and it shouldn't work that way. Any ideas? I have several elements with almost identical body parts and I don't want to make set files for them separately. Thanks for your help in advance - Walter
