Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 03 6:55 am)
Attached Link: http://forum.daz3d.com/viewtopic.php?t=2747
You can use easy the unimesh from Almo (see link). Use the V3-Unimesh with SheFreak-Unimesh morph. http://forum.daz3d.com/viewtopic.php?t=2747 And you can convert conforming clothes too! MazakOk let me explain ;-) Load V3-Unimesh from Figures->Mannikin Puppets Load a Dynamic Clothing prop Go to frame 20 and set the Shefreak body morph to 1 in Unimesh. In animation palette use Break Spline on frame 20. Go to Cloth Room and create for the cloth prop a simulation with 30 frames. Calculate the Simulation. When the simulation has finished export the clothing prop as wavefront object. Export as single frame; Start frame 30, End frame 30. In 'Hierarchy Selection' select only the cloth prop. Export with default settings. You have now a new cloth object that fit your SheFreak figure. Create a new scene and re import the object in Poser; deselect all import options. Save the new prop to your Dynamic cloth folder. Mazak
Is there a way to use V3 dynamic clothes on the She Freak. I've been trying to figure out a way to add the She Freak as a morph target to V3 so I can turn her on and off. Is there a way to do it? Or is there another way to fit She Freak into V3 dynamic clothes?
