REnder every image large and shrink it? I render my cartooned images quite large and then shrink them smaller to clean the lines.
3-D Arena | Instagram | Facebook
I do not feel obliged to believe that the same
God who has endowed us with sense, reason, and intellect has
intended us to forgo their use.
-Galileo
What color are you rendering against? What format are you saving/exporting as? Are you rendering an image or a single-frame movie? Poser will include an alpha channel, but some formats seem cleaner than others. You may also want to look at "cartoon with line" mode or some of the sketch render styles to come up with a look which will harmonize with the look of the backgrounds/props. Carolly
You can render as tiff over transparent background, delete the background, then shrink the image while it's in its own layer over the new background. It's a classic APS technique, which they could explain in detail in the Photoshop forum. If you shrink the image after clicking on the background color and then deleting the background color, you'll always get resizing artifacts like that when you try to cut-n-paste it into a new image.
