Mon, Jan 6, 12:16 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 05 11:51 pm)
Subject: too much in the pose library??
JayCeeRD ( ) posted Thu, 12 February 2004 at 11:04 PM · edited Mon, 06 January 2025 at 12:16 AM
Hi, It seems that I have too many pose directories in the pose library. While in Poser, when I try to access some of the pose directories (the ones down at the bottom), Poser doesn't pull them up. Does anyone else have this problem? Is there a way to get rid of this limitation? (Other than what I'm doing... temporarily moving some of the directories out of the pose library directory). Thanks for any help, john...
Bobbie_Boucher ( ) posted Thu, 12 February 2004 at 11:17 PM
Get PBooost from the Marketplace. It's the best $25 you'll ever spend. You'll be able to divide your stuff into banks, and switch back and forth between them. Works great.
hauksdottir ( ) posted Thu, 12 February 2004 at 11:21 PM
There is a well-known limit of 256 folders in any library if you are using Poser 3,4 or ProPack. If you manage your libraries and only have installed what you truly need and are using, it is easy to stay within this. If you let files install themselves willy-nilly or install megapacks with 40 shades of eyecolor and 20 lipsticks... you will run out of space real fast. A few merchants are setting their MATs to install in the camera or other directory, which I find even more deplorable. That ONLY increaes the clutter and who in this middle earth is going to search-and-destroy eye color MATs if they are hiding under cameras or lights? You have a few choices. The first is most obvious: backup your files and thin down the Runtime. This will allow it to load faster and you will be able to find what you need without scrolling endlessly. The second is to purchase a product called PBooost which may or may not work for you, and which is PC-only. You will then have to organize your folders into ranks which can get loaded. The third is to upgrade to Poser 5 which has nested directories and the ability to have multiple Runtimes. You won't have to throw anything away, but you will still have to organize your stuff so that you can find it again. There are people who chafe at the limit... but the alternative is scrolling through 12000 names hunting for that lipstick! Carolly
JayCeeRD ( ) posted Thu, 12 February 2004 at 11:35 PM
Thanks. That answers the question. It doesn't really help when Victoria 3 and Michael 3 throw in all these !MATs and INJ/REM options in the pose library. I'd rather just have all the morphs up front when you load the model. thanks again. john...
sturkwurk ( ) posted Thu, 12 February 2004 at 11:38 PM
I took all of those INJ/REM files and cut them in half. I added a + sign to all of the INJ poses, and then just put the REM poses in the folder. That got rid of half of them easily, and kept the names easy to sort. Doug
I came, I rendered, I'm still broke.
KateTheShrew ( ) posted Fri, 13 February 2004 at 12:27 AM
Another thing you can do is consolidate some of your folders. I can't tell you how much space I gained by taking all the folders that had only one or two MAT poses in them and sticking them all in one folder named, you guessed it, MAT Characters (with the appropriate V1, 2, or 3 tacked onto the front to keep it organized). So now, all those single mat files are in V1 Mat Characters, V3 MAT characters, etc. Got rid of TONS of folders just with that alone. Kate
sturkwurk ( ) posted Fri, 13 February 2004 at 8:09 AM
Great Idea Kate, I've also consolidated by merchant name instead of Item. and even "MAT Daz Hair" "MAT Daz Animals" and so on.
KateTheShrew ( ) posted Fri, 13 February 2004 at 8:45 AM
I tend to consolidate more by item and type of pose. Makes it easier for me to find what I'm looking for. Cataloging by merchant would be a nightmare for me because then I'd have to keep a separate list of which merchant did what. Not exactly speedy when I'm looking for the mat or mor files for a V3 character and can't remember which merchant made it. :)
hauksdottir ( ) posted Fri, 13 February 2004 at 9:45 AM
Whether you organize by character (Vicki, Natalia, Mayadoll) or merchant (PhilC, Anton, SergeMarck) or type of item (clothes, vehicles, plants) isn't as important as simply being organized. Any system will work as long as there is a system for installing and finding things. With thousands and thousands of files, this becomes vital. I don't let anything install itself... not even DAZ installers... because I want to know where it is going and why. Carolly
KateTheShrew ( ) posted Fri, 13 February 2004 at 12:02 PM
Same here. I always install to a temp folder first so I can organize and then run correct reference BEFORE putting everything in my poser runtime. This method also helps to keep poser from calling up the wrong texture so I don't wind up with a black dress texture on a hair model. :)
Bruce_ ( ) posted Fri, 13 February 2004 at 1:12 PM
There is a cheap fix, poser can import pp2 props, there is a free poser file manager in the free stuff under utilities, with it you an search the files by image in the moved directories, then when you find the prop you want you simply import it into poser.
Bruce_ ( ) posted Fri, 13 February 2004 at 1:15 PM
I think storing the inj morph in the figure is alot more easy then leaving them in a file to be injected.
xoconostle ( ) posted Fri, 13 February 2004 at 3:43 PM
As a Poser 4 user, I keep a separate pose folder outside of Runtime, but within the Metacreations>Poser folder, for poses currently not in use. This works pretty well for me, although I sometimes forget what's in there as opposed to what's in the actual poses folder. The only reason I'm not buying PBoost is because I want to see what Poser 6 will be like, first. :-) This is an excellent thread. Big thanks to Doug re: the INJ/REM poses idea.
ming ( ) posted Fri, 13 February 2004 at 4:08 PM
PBoost doesn't work right if you have a FAT32 system.
nruddock ( ) posted Fri, 13 February 2004 at 5:06 PM
Attached Link: http://www.renderosity.com/freestuff.ez?Form.Contrib=kamilche&Topsectionid=0
If you have ProPack, there is a script in FreeStuff that will help.
Coleman ( ) posted Fri, 13 February 2004 at 9:42 PM
Online Now!
I separate the poses that begin with !!!!!!!!!!! from the poses that begin with +++++++++ lotza luv :P
hauksdottir ( ) posted Fri, 13 February 2004 at 10:00 PM
LOL! I rename everything. If I want it to appear at the top of the list, that is my choice... NOT a vendor's act of self-promotion.
