Fri, Jan 24, 8:12 PM CST
Forum Moderators: Staff
Subject: Runtime Mac -> PC Migration Issues
Dendras2 ( ) posted Fri, 13 February 2004 at 12:26 AM · edited Thu, 09 January 2025 at 9:20 AM
Finally, after several years of foot dragging, Im migrating to a PC from a Mac for a myriad of reasons, none of which are the focus of this thread. Ive installed Poser 4 with both upgrades recommended by CL, and Ive dragged over an inordinately large Runtime folder (50 gigs) into the Poser 4 folder. The files within have all been translated to PC format using Mac Converter. I can open each folder and see the files with. So far, so good. Now when I open Poser on the PC, the library categories show up, but within those categories, nothing appears. For example, under charactersanimals, none of the animal characters appear in Poser. On the desktop, however, theyre showing up as text files WITH the .cr2 extension visible: For example, I have Tiger (the rsr file) and(Tiger.cr2 in the Animals folder. Anyone have any ideas on whats causing this, and if so, what the fix is?
lesbentley ( ) posted Fri, 13 February 2004 at 12:53 PM
Which OS are you using? You say the library files are showing up as text files. If you mean the file type as seen in the Windows Properties box is 'Text Document' then that's wrong. The file types should be listed as "RSR File", "CR2 File", "PP2 File" etc. There may be a file association error. It sounds to me like there has been a fault in the Poser 4 instalation, I sugest that an uninstall/reinstall may be the best way to proceed.
Dendras2 ( ) posted Fri, 13 February 2004 at 1:01 PM
I'm using XP Pro, and I just tried doing this again by adding a converted character to Runtime, instead of trying to replace the Runtime folder, si I imagine that you're right about the issue being an installation issue. In the event that this IS a file association error, how does one correct that? And thanks, BTW. Appreciate the help.
