Mon, Nov 4, 11:28 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 04 10:34 pm)
Subject: FireFly Renderer not workin..black screen?
_Fredzz_ ( ) posted Sat, 14 February 2004 at 11:32 PM ยท edited Mon, 04 November 2024 at 9:26 PM
hey.. i was making something in Poser 5.. when i try to render with FireFly (draft or production,doesntmatter) it starts rendering but when its over i see only a black screen.. and if i try with Poser 4 renderer it works fine!! why is that? Right.. i can render with Poser 4 renderer but Firefly has more quality, right? so why doesnt that damn thing work here? =) thanks
marvlin ( ) posted Sun, 15 February 2004 at 4:00 AM
When you say "It's over", is it actually over, or are yo assuming it is. When rendering in firefly the window can appear to be balck at first but the images will slowly appear in tiles, I know this is obvious but just in case, I thought I'd mention it :o) The other reason could be "Firefly" uses a lot more memory than poser4 mode, so it could be that the window apears for the actual render to start then your machine can't cope and effectivley gives up leaving you with a part rendered image, or a black picture. Again you may have alreay done this, but just get a primituve object, sphere is good, apply a texture and a bump map, then render in firefly. If it works, I would argue that the you a RAM deficiency, if it doesn't then the problem is indeed with poser or something within the scene you are trying to render is causing the image to fail. Hope this helps, probably wont LOL, but I tried :o) MaRv
i7 5930K 3.60Ghz | ASUS X99-S Motherboard | Crucial Ballistix Sport 32GB DDR4 2400MHz RAM | NVIDIA TitanX | Antec 1000w Power supply | Windows 10 x64 Home
marvlin ( ) posted Sun, 15 February 2004 at 4:01 AM
LOL, sorry about the poor typing, I'm still a little drunk from last night :op
_Fredzz_ ( ) posted Sun, 15 February 2004 at 10:04 AM
lol.. that might help even if you were drunk ... lol.. i'll try.. its 17.11 i just woke up.. so.. cheers :)
