Look for a program called i5comp. It can extract files directly from the data1.cab where all Poser files are located. This .cab file is in your Poser install directory. There's a thing I do that is pretty useful: burn the Poser directory to a CD right after you install it. You can later delete the files you don't want in your HD and, if you need them later, just copy them from the CD. You can even run Poser from the CD...
WZN, I don't see a data1.cab in my Poser Propack directory. Is the "Poser install directory" something other than ...Curious LabsPoser4?
All Microsoft operating systems which use CAB's include a program called EXPAND which will also do the job of extracting files from a CAB. It's a command line program, though.
Ok, after first installing poser 4 and pro pack I customised my install, (read deleted all the stuff I didn't want) and proceeded to install victoria, mike, etc. Now, I've purchased the clothing converter from the 'Rosity marketplace and am happily sharing my characters wardrobe around. I've come across some old freebies for posette (whom I've deleted) and would like to convert them, unfortunately I can't do this unless I have access to the 'cr2 file for her, so does anyone know how/if I can extract posette in all her glory from the poser install file without re-installing & probably messing up my current install. I'm running windows xp home & only have one partition on my hard drive.
