Sat, Jan 11, 12:51 AM CST
Forum Moderators: Staff
Subject: adding a 'Taper' dial to a prop?
Elfwine ( ) posted Wed, 18 February 2004 at 3:21 AM · edited Fri, 10 January 2025 at 9:52 PM
I've made a prop using Poser's primitives. I'd like to add the "TAPER" dial to the prop. I've tried hacking what I thought was the taper code from a simple .cr2 file, into the .pp2 file but the dial refuses to show up.
I'm trying to fit a bit and bridle prop to Mikey.
The easiest way to imagine this is a simple box prop, add a 'taper' dial to it and you can narrow the top.
Can this be done?
 Don't sweat the petty things, and don't pet the sweaty things!  ; )
EnglishBob ( ) posted Wed, 18 February 2004 at 7:19 AM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=819348
See this thread for answers - and some laughs too. :D
Elfwine ( ) posted Thu, 19 February 2004 at 1:37 AM
Wow. That was quick. Thank you, EnglishBob. : )
