Mon, Dec 23, 7:29 PM CST
Subject: Evil Banding
Angelouscuitry ( ) posted Thu, 19 February 2004 at 5:33 PM ยท edited Mon, 23 December 2024 at 12:37 PM
Anybody want to ticjle my fansy my attempting to explain any one of the many reasons, I can imagine, being the cause for the bands I keep noticing in this scene's Ultra render, please? This is the only, of my first 6 sky backgrounds, that leaves a band. I've prayed never to see a render angine do this, on a good setting. I'd very much like to always avoid this in the future!
Robot17 ( ) posted Thu, 19 February 2004 at 9:32 PM
Don't know what you're talking about. I don't see any. Could be my eyes or your monitor. Try posting a larger image with the defect pointed out. Bot
agiel ( ) posted Thu, 19 February 2004 at 11:28 PM
Angel.... can you make sure your monitor is set to 32 bit color depth ? If I set my resolution to 16 bits of colors, I can see banding, especially in the lower left corner. But if I switch to 32 bits, the picture is just fine.
DMM ( ) posted Fri, 20 February 2004 at 7:16 PM
I'm running 32 bit and I can see banding there. But, as its probably a jpg picture I can't say I would see it in its original form.
Flycatcher ( ) posted Fri, 20 February 2004 at 8:02 PM
Yes, I agree with DMM - there is slight banding at 32 bit. It's a little easier to see if you mask out the bright central band with your hand. As Angel raised the question, presumably it's not just a JPG artifact and is evident in the original image too. I have seen similar (and worse) banding in Terragen, but not in a Vue sky before. My only thought is have you tweaked the gamma either in Vue or in post? I have found that doing so in post (or using PSP's Clarify filter) on a Terragen render can create very obvious bands in large blue graduated areas of the sky that were barely if at all noticable originally.
