Fri, Nov 15, 11:57 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 15 9:11 am)
Subject: uhm props with my first hair model
Paradogma ( ) posted Sun, 22 February 2004 at 6:13 AM · edited Fri, 15 November 2024 at 11:56 PM
well, I attached a Render of my first hair model, its my first attempt that I have used Rhino, therefore I think it`s not such a bad job, but i have problems with the hair. Especially with the hair around the ear. I have no idea how to draw such curves in rhino. The other thing is the texture. When I opened it in UVmapper and remapped it as good as I could I got out something weird.... I reply to my own post and attach the texture for you to look at it. I post that here, because I think its poser related. I need poser artists to help me creating hair... By the way, thanks to those who helped me and thanks to the tutorial at 3DUniverse, that was a big help. Praada
Paradogma ( ) posted Sun, 22 February 2004 at 6:16 AM
Thats the texture I meant. the thing on the right side is the hair. Maybe you see what I mean.... Praada
SAMS3D ( ) posted Sun, 22 February 2004 at 6:30 AM
What are the 2 circles? Sharen
Paradogma ( ) posted Sun, 22 February 2004 at 6:35 AM
I wish I would know:D Those are my problem.
geep ( ) posted Sun, 22 February 2004 at 6:42 AM
Skull cap?
cheers,
dr geep ... :o]
edited 10/5/2019
Paradogma ( ) posted Sun, 22 February 2004 at 6:46 AM
no the scullcap is on the left top corner, geep.
geep ( ) posted Sun, 22 February 2004 at 6:49 AM
Two large pieces of dandruff?
cheers,
dr geep ... :o]
edited 10/5/2019
Paradogma ( ) posted Sun, 22 February 2004 at 7:01 AM
uhm no, I dont remember that Ive added dandruff:) The whole model consists of two meshes. Hair and Scullcap. The Scullcap is at the right top corner, the hair on the left. I have no idea what those circles are, but they cause the texturing Problems, and I have no idea how they got there.
SAMS3D ( ) posted Sun, 22 February 2004 at 7:32 AM
Can you select them in UV mapper, hover over the circles, right click and then click geometries and if you can select just the circles look at it in the View, Show model...are you using Pro first of all? Sharen
Paradogma ( ) posted Sun, 22 February 2004 at 7:55 AM
hm unfortunately doesnt work...Well I dont own the pro version, just the demo version. despaired Well....could it be ...I mean I ve used lots of different curves for the hair...could that cause the prob? or would it help if I post the UVS ? *help**can i just post the uvs? I mean its a big file...lots of questions....well damn thanks that a few of you want to help me:)) Praada.
steveshanks ( ) posted Sun, 22 February 2004 at 8:32 AM
They lok like they may be the caps on the tips of the hair..Steve
SAMS3D ( ) posted Sun, 22 February 2004 at 9:08 AM
I agree with Steve, looks like a cap. Sharen
Paradogma ( ) posted Sun, 22 February 2004 at 9:24 AM
thanks steve and sharon:) Now that I know that those could be the caps.......back to my first question how to texture them, or how to separate them from the rest of the hair. Because they really make no sense to me. I tried to tile the map but didn`t work. Im really a beginner in creating objects, but any of us started little. :) Thanks again for helping.
steveshanks ( ) posted Sun, 22 February 2004 at 9:47 AM
I'd just delete them if you can..i'm not sure how rhino does it but the app i use will let you choose if you want them or delete them later..or in uvmapper you select a polygon and then get it to grow the selection till it has all the caps selected...Steve
Paradogma ( ) posted Sun, 22 February 2004 at 11:10 AM
mmh...I try that....If it works I`ll put a note here. Thanks Steve:) Praada
Phantast ( ) posted Mon, 23 February 2004 at 5:00 AM
You should be able to get a better map than that out of UV mapper - try experimenting with different split options in planar mapping.
SAMS3D ( ) posted Mon, 23 February 2004 at 10:24 AM
Hi, I zipped it up and sent it back to you....found out those circles are the ends of the hair. Your hair is solid cylinders so there are 2 ends with each strand, top and bottom, I separated them out and moved them to the end of the map. Let me know what you think....it was emailed to you. Sharen
Paradogma ( ) posted Mon, 23 February 2004 at 11:29 AM
Thanks again Sharon, I just came home and found it! That`s a lot better now and as weird as it was to me, I did learn something new today:D! Thanks to all of you! Praada
SAMS3D ( ) posted Mon, 23 February 2004 at 11:58 AM
You are quite welcome. Sharen
