Thu, Nov 28, 11:56 AM CST
Subject: Easiest way to make a chain?
draculaz ( ) posted Sun, 22 February 2004 at 5:43 PM ยท edited Sat, 17 August 2024 at 1:16 PM
been thinking about this... i figure that it would be easier to make it in bryce than wings... but i'm still fuzzy on the particulars of making it 'fit' in the easiest way... you know what i mean, the links fitting, and what not. is it done through parenting or what? drac
Mrdodobird ( ) posted Sun, 22 February 2004 at 6:41 PM
Well, as a test one day I stole the "smartpipe" idea and instead did it with chain links. (well, I didn't "steal" the idea, as I didn't know about it at the time, but I learned later) So if you remember anything about the smart pipe thing a while back, just replace the metaballs with chain, Each one at a 90 degree angle to the one next to it so they all fit. True, it isn't perfect, (every once ina while it doesn't intersect correctly) but it works easier than the alternative.
ibassplayer205 ( ) posted Sun, 22 February 2004 at 6:44 PM
Attached Link: http://www.geocities.com/SiliconValley/Haven/2470/chaintut.html
heres an idea, using mothin paths for making chains. really cool
Mrdodobird ( ) posted Sun, 22 February 2004 at 6:47 PM
And here I had thought I was being original.
draculaz ( ) posted Sun, 22 February 2004 at 7:06 PM
cheers!
TheBryster ( ) posted Sun, 22 February 2004 at 7:33 PM
Forum Moderator
There's a chain device is the poser free stuff I think. If not I think I've still got mine somewhere......
Phantast ( ) posted Mon, 23 February 2004 at 5:12 AM
A certain person called Thrallord made a pair of chain links out of Bryce booleans a long time ago. I still use them occasionally; it's a good way to get a quick chain on the fly.
bikermouse ( ) posted Mon, 23 February 2004 at 9:54 PM
you can multirep links along a path in the same way as that tutorial duplicates links; each link rotating 90 degrees(y) and offset in the(x) axis. It takes a little practice to get right, but once you get used to it multirep is faster than duplicating each link.
