Thu, Dec 12, 8:19 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 12 3:30 am)
Subject: reflection question
ZoSoSwiM ( ) posted Mon, 23 February 2004 at 4:24 PM · edited Wed, 11 December 2024 at 4:08 PM
hey, I want to render a picture with a realistic reflection of the character i'm using. Something like a mirror would produce. I saw the reflection tutorial on this site, but it produces blurry images. What can i do, or where can i go to find this information??
SamTherapy ( ) posted Mon, 23 February 2004 at 4:37 PM
Attached Link: http://www.cocs.com/poser/reflectp5.htm
Try the link. It tells you exactly what you need to know.
stewer ( ) posted Mon, 23 February 2004 at 4:37 PM
Were you using the draft settings when rendering? The shading rate in the draft settings is too big for sharp reflections, you need to lower it to 1 or 0.5 to get sharp reflections. In my experience, mirrors with less polygons work better than ones with many polygons (for example, the single sided square renders much better than the cloth plane - and uses less RAM too).
ZoSoSwiM ( ) posted Mon, 23 February 2004 at 7:09 PM
I went to that place and it helped the renders, but they are still blurry. What can I do to improve the quality? I want some nice sharp reflections!?
Mec4D ( ) posted Mon, 23 February 2004 at 8:30 PM
they are not blurry they reflect also the light.. plugin the reflection node under the Alternate diffuse set the alternate diffuse to white color and the reflection to the color you wish and everything will working fine.. use also Production rendering as stewer explain for sharp edges.
_________________________________________________________
"Surrender to what it is - Let go of what was - Have faith in what will be "
