Sat, Nov 30, 11:19 PM CST
Subject: SR4 Update Different problem
d-larsen ( ) posted Mon, 23 February 2004 at 8:33 PM ยท edited Tue, 26 November 2024 at 9:45 AM
I just updated to SR4 on P5 and now I can't change the background colors when I go to Display>Background Color and select a color. This is the same whether it's a new project, PZ3, or one of my previous projects. Using XP Pro OS and have reporte to Curious. Anyone else upgraded that can't do this either?
uli_k ( ) posted Mon, 23 February 2004 at 8:51 PM
Hi d-larsen, this section from the SR4 readme might help you: Material Room ------------- - Corrected an erroneous condition where multiple, disconnected nodes were added to the background color node. As a result, the background color was not editable any more. This problem is fixed in SR4. However, if you still happen to have files where this condition is present, there are a couple simple steps you should take to correct them: 1. Open the problematic file 2. Go to the material room 3. From object menu select background. You'll recognize that there are duplicated nodes. 4. Select and cut/delete all duplicated nodes except for the "BG Color" node that was originally connected to the Background root node. 5. Save the scene. In case you have set to open new documents with your preferred state, the problem still will reproduce in files created by File->New. Please repeat the process described above after creating a new file and set the preferred state again.
d-larsen ( ) posted Mon, 23 February 2004 at 9:13 PM
As soon as I resave the old file or save a new file as the readme says to do the Material Room shows the multiple background nodes again.
d-larsen ( ) posted Mon, 23 February 2004 at 10:04 PM
Had to go in to the Runtime>Pref folder and delete the preferredstate.pz3 file and open Poser in Factory Default State and then create a new preferred state setting. Oh well, sometime you gotta read between the lines of the readme file!
