Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 09 1:04 pm)
Attached Link: P4-puchar 800KB without sweet hearts
here is for poser4, I set the glass as parent for the flowers and the rest of decoration so you can compose own things , when you open the scene save first the prop in your favorite folder.._________________________________________________________
"Surrender to what it is - Let go of what was - Have faith in what will be "
Attached Link: for Poser5 materials included
for Poser5 try this one_________________________________________________________
Thanks :)) did you try out the right rendering settings? draw mode is not so good for the final touch.. the model have all the same materials but you need use also the ground for that.. it is well very funny, if I render the glass without ground, it reflect the flowers but when I put the glass on the ground it reflect then only the ground and a little the edges, nice effect as well but you need use here also only gray light.. I use 3 light set.. 2 spots and one global without shadows.. The velvet is one of the amazing shader node in poser5, I use this also for glass, this create soft look of the model and the hard dark edges are gone.. no matter skin fur or glass. Amazing for dark surfaces, as black for example, you can render your models on all backgrounds you wish without to worry they will not visible.. there is little trick also on the final first image with the color (stars) this is a PS plug-in filter by Andromeda called Scatterlight that add the nice colors around the highlight of the glass.. I add only the colors the rest was original poser 5 rendering. Cath
Attached Link: Download: for Poser5 materials and light included size: 1.5 MB
as the subject say.. click on the sphere after your open the scene with Poser and you find 12 funny fantasy morphs included.. have fun! save the figure to your favorite folder.. cath_________________________________________________________
Attached Link: Download: for Poser4 light included not materials size: 1.5 MB
download for poser4_________________________________________________________
Cath this is great! Thank you very much :)
Poser 9 SR3 and 8 sr3
Processor Type: AMD Phenom II 830 Quad-Core
Hard Drive Size: 1TB
Processor - Clock Speed: 2.8 GHz
Operating System: Windows 7 Home Premium 64-bit
Graphics Type: ATI Radeon HD 4200
System Ram: 8GB
I love this object, it's beautiful, but I'm a bit confused on how to extract the files needed to add it to my libraries. I've downloaded both versions and they both ask for an .obj object and a .bmp when loading. How do I get those to load the .pz3? And then there is the morphs, how do I save those and use them on the bowl?
is that with the first one or the magic shape? with the magic shape open the pz3 scene with Poser then safe the bowl in your figure folder not prop, the bowl is a figure// when you have open it click on the figure and you will see the morph and dials, use the dials to get right form you wish. so one time again.. the first object above is a prop, and the magic shape is a figure with morphs included.. save props to props folder and figure to figures folder of your choice.. let me know if that works..
cath, thanks for the reply, here is what I did. I opened magic-shape-p5.pz3 and it asks for Magic Clay.obj which I don't have so I cancel that and then it asks for a magic_sphere.bmp which also I don't have. It finishes loading, a grey background loads with a Figure 2 and all the morphs. The trouble is I don't see and can't click on any object. I saved that to my figures, but there is nothing there, just the morph dials. BTW, I am using P5. I can load the puchar-p5-materials.pz3 and the object does appear and I can save it to my props and materials. Very nice material too!
![file_99054.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_99054.jpg)
messed with Zbrush a little bit creating eyeballs and ended with this one.. If you like I will ziped the files and upload for you.. Note: 30.000 poly huge sweety with sweet hearts 70.000 created from one cube, balls and squares..and set up as a prop together in poser.. Woho!! hahahaI ask because my freebie section is not Online..
Let me know
cath P.S rendered in poser5.. if you wish I can set up a scene with all materials included that I used above and everything was just a shader nodes..
