Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 7:53 am)
present. but not wrapped as one though....
Does this mean that there's no way you can make a die using a displacement map? With indented dots (or whatever they're called)? without breaking up the box?
"Does this mean that there's no way you can make a die using a displacement map?"
Hi ernyoka1,
NO ... but you have to think "outside the box."
Can you guess what is necessary? ;=]
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
cheers,
dr geep ... :o]
edited 10/5/2019
Oh and does anybody have an idea of what causes that weird black shadow on the box too?
cheers,
dr geep ... :o]
edited 10/5/2019
So is there any way to get rid of the squares that the Bucket size produces? Other than operating with a huge bucket size and watch your processor melt G For some effects, like fur, you need a displacement value of 1 or more, but it does make that annoying square effect.
that in no means was ment to be an insult or anything it was ment to be a compliment. im sorry if it came off badly i love your humor but i do have a hard time figureing where at first it starts and where it ends on a page :) Keep up all the awsom work im saveing all your work so i can go back to it and reread at a moments notice i cant wait to find out what comes next ^_^ i hope you post a link to it on this thread so i can find it without haveing to search like you did with this thread and the last part
Ah great! Thanks for that tip, bip :o)
Also don't forget you can put a math function between the displacement node and the 2d imag e(displacement map/bump map). For example, you can have so,me math that subtracts 0.5 from the image map. This would mean that 50% grey would be no displacement, black would be maximum displacement "into" the object and white would maximum displacement "out of" the object. I find this particularly handy as many bumpmaps are designed to have 50% grey at "surface level" with darker being indents and lighter being raised bumps - this math trick in P5 displacement achieves that effect nicely (most of the time). Cheers, Cliff
Cliff.. Please bear with me. I'm a total imbicile at math. Would you mind posting a screenshot of that math node so I know that we're on the same sorta page? :o) TIA
Ya - but only real simple math (simple enough that I can understand it). Anything much more complex than I've done here I'd prototype in a spreadsheet - so that I can see the range of values produced over a series of frames. Hmm, haven't done that for a while - shows how limited I've been in my explorations of the material room :( Cheers, Cliff
![file_100259.gif](https://live.cdn.renderosity.com/forum/_legacy/file_100259.gif)
FYI - You can find Pages 1-10 of this tutorial if you click [ HERE.](http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=1663563) cheers, dr geep ;=]Remember ... "With Poser, all things are possible, and poseable!"
cheers,
dr geep ... :o]
edited 10/5/2019
